Moly grease contamination
carl
09-05-2000 16:10:37
recently a brain dead employee used a drum that had moly grease residue to carry diesel fuel to several engines.We have had a steady diet of filter problems ever since. Draining and hot water flushing has been in effective,fuel additives are useless....is there a solvent to flush the tanks out that is compatible with diesel? these tanks hold 10 gallons that will not drain or can't be siphoned. Any remedy short of replacing the tanks?
Burrhead
09-06-2000 10:34:40
 Re: moly grease contamination in reply to carl, 09-05-2000 16:10:37
We have that same problem here about twice per year without fail.
The grease should pass on through after it soaks a few days. I know that does'nt relief the problem now, but I don't know of anything that will break it down that won't hurt the engine.
If you take the tanks off you can slosh them clean with gasoline or acetone, or you can get them vatted at a machine shop. The machine shop vat is cheaper and quicker around me.
Burrhead
09-06-2000 10:34:39
