Tool Talk Discussion Forum
How to Weld Grader Blade and Bucket Teeth?
Dave Crosby
03-02-2004 21:15:06
Hi All,
I need to make a tool for my excavator that will involve welding a cutting edge off of a motor grader to some old bucket teeth.
I've cracked a few pieces of blade, and I'd like to get some advice on what rod to use, how to preheat the blade properly, peining after welding, and anything else that might be useful.
Any other observations or advice on welding steel used for cutting edges on earthmoving equipment is much appreciated.
Thanks,
DRC
Dave Crosby
03-04-2004 19:50:26
 Re: How to Weld Grader Blade and Bucket Teeth? in reply to Dave Crosby, 03-02-2004 21:15:06
Thanks to all for the tips so far.
I'll try to clarify this some, I guess I should have given more details the first time.
This is about 3' of grader blade that I need to weld to two teeth that are about 14" or so apart on a 24" bucket. The fit is poor, there isn't a lot I can do about that other than fill it in or weld up some pads on the teeth that conform to the blade.
Last go-around the welds held up fine, but the blade cracked in a few places. Seemed like maybe too much restraint (the teeth were on the bucket, of course), or maybe the temp on the blade came down too fast.
I've tried a few different rods, including 7018, and some rod formulated specifically for wear edges.
I've been welding off and on since 1972, can run MIG, TIG, stick, and gas, (I know those terms date me (grin)),and have welded motor and transmission cases successfully, so I have at least a rough idea of what I'm doing.
This one has me a little stumped, though. I've never seen steel this strong crack like that. If the welds were cracking, I'd figure it was just me, but the welds seem to be fine.
After reading all of your advice I'm wondering about preheating everything to about 350F, welding it up, and bringing it down slowly.
I'm also wondering if I do this, how well can I expect these teeth to fit back onto the tooth mounts when everything is cold.
Again, any advice is most welcome.
DRC
Greg Or
03-06-2004 08:12:22
 Re: Re: How to Weld Grader Blade and Bucket Teeth? in reply to Dave Crosby, 03-04-2004 19:50:26
HI Dave
With only two contact points on the grader blade using the teeth as the moldboard backing [2"aprox.] with 10" of overhang and the hyd. rip-out force of the excavator, I think I would take a step or two back and re-think the design on this tool as the grader blade will not hold up to this kind of flexing.
T_Bone
03-04-2004 21:20:55
Hi Dave,
Describe the cracks in the base metal. How far away are the cracks from the weld zone? Grind a V into the crack and see how deep the crack goes. More than one crack? Crack Length and width? Is the crack transverse (horzontial) to the weld joint?
I was thinking you were talking about the welds cracking.
T_Bone
T_Bone
03-04-2004 12:00:16
Hi DRC,
Usually grader blades weld easy without a cracking problem. Did you preclean the area well? Good joint design? Tight fit-up?
I would probably use a torch after grinding clean to remove the steel of any moisture, oil, grease, rust, paint, before welding, about 500�.
T_Bone
Fred OH
03-06-2004 10:10:15
 Re: Re: How to Weld Grader Blade and Bucket Teeth? in reply to T_Bone, 03-04-2004 12:00:16
T_Bone...do you think maybe he might be into manganese steel? It seems to give those same symptoms as I recall..."harder than chinese rithmetic" to weld. I think most cutting edges and bucket teeth are just high carbon heat treated steel(?)...but you never know. Maybe annealing the part first would work...but there goes it's toughness. Fred OH
T_Bone
03-06-2004 14:13:47
 Re: Re: Re: How to Weld Grader Blade and Bucket Te in reply to Fred OH, 03-06-2004 10:10:15
Hi Fred,
Yep I do and thats why I wanted him to describe the cracks. I kinda have a feeling the blade steel isn't a common type.
With the different metal mixing techology into todays world it's getting tuff to recomend a general welding procedure for anything.
T_Bone
kyhayman
03-03-2004 16:16:31
I just weld them on. From what I've seen, the main cause of weld failures in places like this is experience of the person doing the welding not process. For cutting edges I used to tack with a 6011 and then weld with a 7014 at very high amperage taking care to direct the arc into both pieces of base metal, usually weld 2" and skip 2", then go back and fill in. Of late I've started using 7018; 1/8" with DCEP set at 135 amps. I do strike my arc and then hold it long to preheat my arc starting area to ensure good penetration and mixing of the rod with the base metal.
mj
03-03-2004 07:51:09
I use 7018 rod on DC reverse polarity (DCRP) or AC with a bit of rosebud pre-heat (keeping it below 1100�F ), peen weld area at each weld then finish with rosebud post-heat. I've welded hot-rolled steel 'ice-grousers' to Cat tracks when ambient temps. were in the low teens without the pre or post heat and they stayed on.
