Tool Talk Discussion Forum
Stihl 028 wood boss won't start?
Jeff
03-02-2004 17:14:53
I was using my stihl 028 one day and it just died. I smell gas when I pull it over but it won't start. I think it must be an electrical problem. Do I need to clean up the points? Can a plug just stop working? Any suggestions to get this thing running before spring would be appreciated. Jeff
abjahnke
03-03-2004 22:34:01
 Re: Stihl 028 wood boss won't start? in reply to Jeff, 03-02-2004 17:14:53
i think it could be a couple problems , start with the easiest, which is spark/ then go to gas. now i am on my third stihl. the first one would just quit on me . after i would turn it on its side to do side cuts , that was an o28 wb. after it would sit for a week it would start again. the mechanic checked for blow by in the cylinder, but compression was good. my next one was six years old. and there it just died on me while i was cutting. i took it in and took off the muffler, there was a scored piston and rings, apparently a chunk of carbon or something chipped off in the cylinder and just peeled the rings back, and also scored the inside, so i had no compression. i saw it myself. now i use a liquid called seafoam as an additive to the gas i use now , its suppose to curtail carbon deposits on the head and piston. hope this helps, i just bought a new stihl , its not worth the trouble flixing the old one, as they only have so many hours left on them. and i got a lot of use out of mine. hope this helps
bob
03-02-2004 20:13:09
yes, new spark plug time. Unless you have a very old 028 you do not have points. If it says 028 AVE or AVEQ, the "E" means electronic ignition module. The av stands for antivibration system & Q stands for Quikstop chain brake equipped.
Jeff
03-03-2004 09:35:06
 Re: Re: Stihl 028 wood boss won't start? in reply to bob, 03-02-2004 20:13:09
It is just an AV - not AVE or AVEQ
Joe (Wa)
03-03-2004 10:44:11
 Re: Re: Re: Stihl 028 wood boss won't start? in reply to Jeff, 03-03-2004 09:35:06
Art, appears to have standard ignition. Try this link. Joe
