Tool Talk Discussion Forum
Which process for pipe welding?
TJS
03-02-2004 15:30:34
I want to build a pipe fence.
Which process is preferable: stick or flux-core wire feed?
T_Bone
03-04-2004 11:46:56
 Re: Which process for pipe welding? in reply to TJS, 03-02-2004 15:30:34
Hi TJS,
Flux cord works well for fence building. Tack at the top center and once at 4 & 8'clock, then start at the top and weld "down" to the center on both sides. Easy to fill gaps from poor fit up.
Stick, 6010, is ok, Harder to fill gaps from poor fit-up. Same welding technique, top to bottom.
FCAW/GMAW works well for fence and hand rail building.
T_Bone
TJS
03-04-2004 20:02:05
 Re: Re: Which process for pipe welding? in reply to T_Bone, 03-04-2004 11:46:56
Thanks for the advice everyone.
Having done some more research, I'm leaning towards going with a wire feed. Would a light-duty welder like the Lincoln SP-175 be enough to do the job?
T_Bone
03-04-2004 21:35:09
 Re: Re: Re: Which process for pipe welding? in reply to TJS, 03-04-2004 20:02:05
Hi TJS,
For standard sch 40 pipe, you shouldn't have a problem with the SP-175 for fencing. If your buying the machine for just this job, I would strongly consider a 200amp plus machine.
T_Bone
SHeiserman
03-03-2004 19:37:27
I'd go with stick myself. I'd use 6010 or 11 and 7018, 3/32 diameter. The smaller diameter is much easier to use. 6010 would be sufficient for this project, but the 7018 puts on a pretty cap for ornamental value. Keep a grinder and wire wheel handy, keeping it clean helps immensely. Good luck.
Bill Smith
03-03-2004 12:22:16
I built a corral out of oil well pipe. I used a portable generator/stick welder. Can't remember what I used for rod, 2 or 3 different numbers that an experienced welder told me to use. I don't think I would of wanted to of messed with a wire welder on this project.
old
03-02-2004 17:23:06
I'd do it with a stick welder but I did learn the finer points of welding from a retired pipe line welder and that is all they use for pipe line welding.
LesWV
03-03-2004 08:47:06
 Re: Re: Which process for pipe welding? in reply to old, 03-02-2004 17:23:06
Go with a stick. 6018 or 7018 DC rods if you are using an engine driven welder. Most of the small Flux core wire welders do not create enough heat to make a good weld on gas line pipe.
