Tool Talk Discussion Forum
removing surface rust
Steve
02-29-2004 20:04:29
My square developed a light coat of surface rust over the winter in the shop. What is the best way to remove it without hurting marks? Anything I can spray on it? I hate to buff it on the emery. Thanks.
Steve
03-02-2004 17:05:55
 Re: removing surface rust in reply to Steve, 02-29-2004 20:04:29
Try a process called electrolytic rust removal. It's relatively easy, using a bath, anode, and a battery charger. It's easier to do than explain. Use a Google search for "electrolytic rust removal" and you'll find a lot of descriptions and diagrams.
Ospho
03-01-2004 08:01:30
Try Ospho, It will leave a dark coating but that can be cleaned off.
ray
Davis in SC
02-29-2004 22:28:28
SOS pad wet down with WD-40
rod
02-29-2004 21:04:15
0000 steel wool.
