Ground faulting Drill press
Dunno
09-01-2000 11:10:16
A friend has given me his floor standing drill press. BUT he says that if he plugs it into a ground fault protected outlet, it will trip. He says that he has never been shocked by it (except when he had to pay the bill when he bought it). and if he plugs it into a normal outlet it works just fine. anybody have any ideas where to start looking on this thing? he used it in a metal shop; maybe a stray piece of metal in the motor? are there some things I might/should check? something like resistance from each side of plug to ground...
TIA
paul...
Dunno
09-05-2000 07:00:07
 Re: Ground faulting Drill press in reply to Dunno, 09-01-2000 11:10:16
welp, thanks for the help guys.. I measured the resistance between the plugs and ground (~3megohms) so I then tried it with the switch on or off, and also the light on/off.. not much change..
so I started taking the covers off.. lots and lots of metal dust in there... and low and behold the wires that go to the capacitor (its a cap start) have spots where the insulation is worn very thin, exposing the wires. I am going to fix that and see what happens.
C-ya
dunno.
big fred
09-01-2000 19:11:36
Before you do a lot of work on the drill press, check it with a couple different GFCI circuits. It is possible that the GFCI is bad, not the drill press. If this is the case, let your friend know so he can replace his GFCI.
Bob M
09-01-2000 12:57:09
Could be a bunch of things. Check first for damaged (cut or wet inside) power cord and cord cap (plug). Make sure the power cord is wired properly at both the cap and switch ends. Black = hot, white = neutral and green = ground. If the neutral and ground wiring are crossed anywhere from the cord cap on down it can cause a GFCI to trip. While you've got the switch box open look for metal turnings/metal dust on the switch body. Likewise open the terminal box on the motor and check for proper wiring and for turnings/dust inside.
If all the above check out OK, then suspect failing insulation in the motor windings. Test by taking an ohmmeter and reading the resistance between either of the motor power leads and the motor frame (with the power cord unplugged!) Meter should read a few megohms or infinity. A reading less than about 30K ohms will leak enough current to ground to trip a GFCI when plugged in (= time to replace the motor!)
Good luck! And I wouldn't run your new press until you get it figured out.
ltf in nc
09-04-2000 15:51:47
 Re: Re: Ground faulting Drill press in reply to Bob M, 09-01-2000 12:57:09
I agree with BobM with one exception. The old machinery will trip a GFI w/o much difficulty. I would install a good machine to earth ground and I would use it. Having a good ground will provide a path to ground without going through the operator. The leakage required to trip a GFI is less than that contained in a flashlight battery.
Dunno
09-01-2000 13:24:39
Thanks. Will check it out... I kinda figured it was something like this but also thought "heck the price is right even if I have to replace the motor" (price is that I have to pick it up)
Neil
09-05-2000 15:00:28
 Re: Re: Re: Ground faulting Drill press in reply to Dunno, 09-01-2000 13:24:39
Hmm, just have to pick it up, hu?
Well my recomendation is you do not use it at all. I will even store it safly out of harms way in my shop! :)
Bob M
09-01-2000 14:00:51
I agree with your "price is right philosophy" - I got my drill press (minus the motor...) the same way!!
