Tool Talk Discussion Forum
Air Compressor's
Mark
02-29-2004 08:03:20
I a looking for a air compressor. I looked at Home Depot and Menards and Farm&Fleet. What I don't get is that you can buy a 25gal. tank with a 5hp set up for about $370 but you can get a 60gal tank 6hp setup for $400. The 25gal is 110 and the 60 is 220. Both cast Iron pumps. Whats up with the price? I would like the small one but the bigger one is a better deal. They must not want to sell the small ones I guess.
K-Mo
02-29-2004 13:58:58
 Re: Air Compressor's in reply to Mark, 02-29-2004 08:03:20
Mark, Air compressors are advertized by HP and Gal because unknowing customers want something big with a lot of HP. It's kind of like advertizing vacuum cleaners by how many amps they draw rather than how much dirt they suck up. Want's important is the rated output of the compressor, cubic feet per minute (cfm) at (@) pounds per square inch (psi). Each air tool has a rating such as 3cfm @ 90psi for a brad nailer or 6cfm @ 90psi for an air sander. The tools you will use determine the cfm@psi rating you need. The tank size depends on the amount of reserve air you may need. An air nailer doesn't need much reserve because it's use is intermittant with pauses to rest. While an air sander or sandblaster uses a constant flow of air and is in constant use, it requires a large reserve. In this case you will need a compressor which supplies substantially more than the sander requires. This will allow the reserve to build up and the compressor to shut down for a rest. I use mine for sandbalsting, painting and I also need 120psi for a spark plug cleaner. It's a two stage rated at 17cfm@175psi. Once you have an idea of the size you need, you can use the cfm@psi rating vs. price to help select the one you want.
Good Luck,
K-Mo
Dave (mn)
02-29-2004 17:54:35
 Re: Re: Air Compressor's in reply to K-Mo, 02-29-2004 13:58:58
On this same note, which is better, cast iron or alu. pump? I would expect the cast iron to be the best?
Charles (in GA)
02-29-2004 22:29:21
 Re: Re: Re: Air Compressor's in reply to Dave (mn), 02-29-2004 17:54:35
Dont waste your time with the oil-less pumps, VERY noisy and wear out fast. Aluminum pump, oil type, with steel or iron sleeve wears ok but are still loud. Iron oil type wears best and last longest and is quietest.
Horse power doesn't mean much, there are two types of HP, starting and running. Most compressors are rated now by their starting hp. In the old days it was always the running hp. One that says 5 hp is really about 1&1/2 hp
My 7&1/2 horse is running hp, peak is 21+ on this, with an 80 gal tank. I plan on running a bead blast cabinet and want lots of reserve. This is a two stage, 175 psi and then you regulate it down to 100 or so, reduces the number of cycles on the motor and pump.
As has been noted, look at the delivered SCFM and compare to what you need for what you are going to be using.
Home Depot Husky and TSC farm hand models are all Cambell-Hausfeld. not the best, but not the worst either. I bought the 7.5 hp Husky. If I were using it everyday, I'd bought a pressure lubricated pump model from IR or Emglo.
Charles
Mark
03-01-2004 07:12:30
 Re: Re: Re: Re: Air Compressor's in reply to Charles (in GA), 02-29-2004 22:29:21
I will not be using it everyday all day but at times it will get a work out. Weekend warrior stuff, tire swapping, a little sandblasting, some painting maybe.
