I haven't set any fires but like I said, have straighten out many electrical circuits that did. I don't know how you can set a fire, or melt the #10 charging wire with the 30 amp fuse in place. If you will read my original response it says to put one wire from the solonoid to the fused wire and the other to the back of the pickup. If the battery on the dump trailer is a good one it won't blow this fuse while the pickup is running. The way you will know the solonoid is not connected while the pickup is starting or the trailer is being dumped assumes two things. One, that whoever is running the dump trailer has shut off his Pickup and set the parking brake while he is out dumping, and the other assumes that the switched wire going to the solonoid to turn it on is on the accessory circuit from the ignition switch. You know, the one the radio is hooked to that turns off while starting. If someone wants to listen to the radio while dumping, then the solonoid will be connected and it may blow the 30 amp fuse. I don't know where you get your metal starter solonoids but I get mine from an RV supplier for about $12 each and they last many years. They are not something special. However, the simplest way to keep from blowing the fuse is like another poster said, Just unplug the trailer connector while using the dump. Another thought for why using a 30 amp fuse is the trailer plug won't take much more anyway. I don't know where all this talk about fires came from unless everyone forgot there is a fuse in the circuit. Even if this was set up with the charging isolators (fancy diode) and no fuse with the pickup running you could heat the wire provided the pickup alternator was putting out enough to charge the trailer battery. The only change I make when using the isolators is using a 30 amp circuit breaker in place of the fuse. They will take more surge and will reset if tripped without operator input. THen there is the really neat and fairly new setups that are electronic controlled. They will connect all batteries to the charger when any battery falls below 12.4 volts and will shed charging load as the batteries come back up over 13.2. Pretty neat for RV's as it takes wasted load off the chassis alternator.
