Tool Talk Discussion Forum
pressure tank
JRS-CAL
02-27-2004 09:52:13
Hi,everyone,My brother has a cabin in Utah and they use a common well for about 6 other cabins. My question is they have a pressure tank at the well house and then the supply line to the cabins.Can he add an addisctional stogage pressure tank at his cabin so maybe more than one shower can be used at the same time? thanks in advance jrs
T_Bone
02-27-2004 12:10:58
 Re: pressure tank in reply to JRS-CAL, 02-27-2004 09:52:13
Hi JRS-CAL,
Your just masking the problem but not solving the problem with an additional pressure tank.
What you need is a pressure pump sized for the system demand with a couple of bladder tanks and a small water storage tank. Your well pump is not going to last very long with the demand it now has.
So pump your well into a storage tank, then pressure the system with a pressure pump from the storage tank. The bladder tanks will keep the pressure pump from cycling on so often.
You can also go with a little higher pressure pump and make up for some of the water volume needed.
T_Bone
Bob
02-27-2004 10:59:44
Jon H's post is correct. You may want to set the bladder pressure in the new tank 5# lower than the main tank but in reality it won't make any difference except you can get a little more water in the new tank with the lower pressure setting.
Make sure that he doesn't leave out the check valve or it will all be for nothing..... ....
Jon H
02-27-2004 10:07:59
Yes,a large bladder tank hooked between the water supply line and the cabin plumbing would work. You would need to install a check valve at the tank inlet to prevent any water flow from your tank back into the water line which would allow the other cabins to steal your stored water pressure.
