Pressure Washer
Leon
08-30-2000 19:09:33
Bought a pressure washer with a 3.75 gas engine.
Puts out 1500 PSI. What do I use for cleaning solution? Local stores have 3 strength's. Cars,houses and a little stronger. I used the stronger solution and it don't seem to do much cleaning my tractors and backhoes etc. I don't want to go to a steam cleaner and was just wondering if there was something else I could use as a cleaning solutiion.....
Vic NM
09-01-2000 06:42:23
 Re: Pressure Washer in reply to Leon, 08-30-2000 19:09:33
Beware of the oven cleaner! A few years ago a friend of mine wanted to remove some decals on his truck. Sprayed on his wife's oven cleaner and hit it with the pressure washer. Removed decals great. Also removed paint and primer right down to bare metal! I don't know if different brands of oven cleaner are different, but be careful.
Stan
08-31-2000 21:32:16
What about running your water out of the cleanout outlet of a outside water heater? Maybe if you don't have one you could find a cheap one and install it close to where you are doing your cleaning. That way you would be cleaning with hot water.
bbott
08-31-2000 19:35:45
For grease and oil ?
Gunk. Gunk Foamy Engine Brite.
Simple green. Wet down. Spray stuff on. Wait about 5 minutes and have at it.
The diesel suggestion isn't bad either.
Next step up is steam cleaner or full-on industrial cleaner.
Remember NEVER spray a diesel engine when its hot or even warm...
Russ
08-31-2000 05:57:48
Spray a little diesel on the greasy areas and let it soak in before you pressure wash. This works real well. A small hand spray bottle usually is good enough unless you have a really large area to cover. Be very aware of potential ignition sources as you spray.
Dean
08-31-2000 02:52:59
Leon,
All the chemicals in the world won't do as well as hot water or steam. Especially true when trying to remove grease/oil.
Dean
Bill D
08-31-2000 16:30:45
 Re: Re: Pressure Washer in reply to Dean, 08-31-2000 02:52:59
Leon oven cleaner to soften baked on grease and then pressure washing will work
Leon Miller
08-31-2000 19:41:31
 Re: Re: Re: Pressure Washer in reply to Bill D, 08-31-2000 16:30:45
Russ...I had wondered about napta or diesel or ever kerosene
Dean I know a Steam cleaner will do it but I don't have one. (^_^)
Bill I t would take a whole lot of oven cleaner on my old Ford 550 hoe.
Still open to comments.....
paul
09-06-2000 21:02:55
 Re: Re: Re: Re: Pressure Washer in reply to Leon Miller, 08-31-2000 19:41:31
Boy, I'd be real concerned about spraying kerosene etc, at 1500 psi! Sounds like an injector nozzle just waiting for a spark...
Also a lot of folks use oven cleanner to remove paint too, so I'd be careful on that as well.
Not much help, am I?
--->Paul
Leon
09-07-2000 07:09:06
 Re: Re: Re: Re: Re: Pressure Washer in reply to paul, 09-06-2000 21:02:55
Hi Paul I think what these guys were actually saying in refrence to kerosene was to brush it on or to use a hand sprayer. After it sets awhile use the pressure sprayer on it.
At least this is the way I understood it.
Anyway, all comments were and are appreciated.
Leon
