Tool Talk Discussion Forum
Shade # for plasma cutting
CM
02-25-2004 04:46:24
What shade number do I need for plasma cutting. The plasma cutter is a Thermal Dynamics Cutmaster 38 (Max 30 amps).
Thanks.
Scott V
02-27-2004 08:49:36
 Re: Shade # for plasma cutting in reply to CM, 02-25-2004 04:46:24
I would use a shade 5 with that machine.You need to see what you are cutting.I had a 29 amp 38 xl,and 5 is about right.I also have a 90 amp esab,and it is not enough really,but ok for short cuts.
Jeff in Va.
02-25-2004 08:39:53
Hi CM.
In my Thermal Dynamics Drag-Gun manual the following info. is supplied:
per ANSI/ASC Z49.1
For arc current less than 300A, minimum shade=8, suggested shade=9
For arc current 300-400A, mininum shade=9, suggested shade=12
For arc current 400-800A, minimum shade10, suggested shade=14.
Hope this helps.
Jeff
