Tool Talk Discussion Forum
power washing with sand and water
bill b va
02-24-2004 12:13:42
any body done this ? how do you get the sand in the water? besides a pressure washer what other equipment is needed ?
Ron from IL
02-25-2004 06:59:43
 Re: power washing with sand and water in reply to bill b va, 02-24-2004 12:13:42
Bill,
Slip over to the N-board and ask for Willy N. He's got one and uses it all the time. He got it (I think) from Northern Tool & Eq. It's a siphon feed attachment that works with your pressure washer.
Ron
jeff
02-24-2004 19:51:28
What are you doing, cleaning a bridge or something? You need at least a 2500 psi with a good 3 gallon per minute pressure washer. Next you are going to use a whole lot of sand and a lot of water. the "tool" you are looking for is called a sand gun. These are used to clean buildings and parking garages etc. No dust in the air but you really need to wash every thing down real good afterwards. The gun sort of looks like a cross between Buck Rodgers blaster gun hooked with a tube to a big bottom feed bucket from a sand blaster. One of the machines I got involved with was used up in Allentown,Pa in a car garage. It was 5gmp. at 6000psi. This thing would just blow old concrete off of the floors! It also had a 40 hp engine on it! Jeff
