Tool Talk Discussion Forum
Taking down a silo
Geo in SD
02-24-2004 05:22:28
We have an old tile block silo that we need to take down to make room for a building. I talked to a guy with a tracked backhoe and he said he would dig a trench and tip it over into it. I would like to not tear the yard up so much. Anyone done something like this before? Any other ideas? TIA
JeffE
02-25-2004 04:59:12
 Re: Taking down a silo in reply to Geo in SD, 02-24-2004 05:22:28
We knocked one down when I was growing up. Tried taking it apart to save the blocks, very slow. We finally started punching out tiles on the bottom one at a time with our eye on the silo. When it finally went we cleaned up everything by tossing everthing into a loader bucket on our tractor and hauled away. Dropped it right in front our our big polebarn without any damage to the polebarn. After reading the other posts I'm beginning to think our technique may not have been the safest way to do it. My mom knocked down another one on an old farm a couple of years ago. Had a guy with backhoe come in, dig a trench, knock down the silo and bury it. Worked pretty good.
Bowling Ball Cannon
02-25-2004 04:35:29
Just within the last couple weeks on the Discovery Channel they showed a old tile silo being taken down with a home made cannon shooting 16# bowling balls. I believe it took about 30 shots to bring it down. Sounds like fun!
Billy NY
02-24-2004 19:06:24
Witnessed one of these tile jobs come down while running a D-8K on a jobsite 10 years ago, a not so brilliant operator in a Komatsu PC-300 excavator got right up close to it, took a few stabs into it without any kind of a plan, needless to say it imploded right on top of him, he was very lucky to walk away from it, damn lucky. I could not believe what I just saw, pile of rubble in a flash. These are really unpredictable, so whatever you do, make sure it's been thought out, you WILL NOT get away from it if it goes and you are too close, its over before its over. If at all possible felling it like a tree has to be the best way, but seeing a few of these implode after a couple of wacks, it's like russian roulette, so best to stay out of its path no matter what you do. Oh and sometimes the inhabitants like rats, will need to find a new home, so best to be prepared for rodent patrol, we did and old wooden one 14 years ago, the rats were big like city rats, scattering everywhere.
Silo-Wrecker
02-24-2004 18:08:25
Fill the silo with water,get in [at the top],in a small boat. Then knock off a little at a time till you reach the bottom. Be careful,have a good time.
John
02-24-2004 18:19:56
 Re: Re: Taking down a silo in reply to Silo-Wrecker, 02-24-2004 18:08:25
Sorry but I can not let this one pass either.....
So lets see; your in a boat 20' in the air with a sledge hammer hitting on a block wall that has been there for one hundred years with all the pressure of the water pushing at the walls of the silo.
WAIT let me get my wife and her video camera first as I want to put that ride on funniest videos also.
DH in Carolina
02-24-2004 18:14:17
Sounds like fun but how do you get the boat in it? DH
Silo wrecker
02-25-2004 17:52:36
 Re: Re: Re: Taking down a silo in reply to DH in Carolina, 02-24-2004 18:14:17
Helicopter and two {2} ropes.
Rusty Jones
03-01-2004 18:19:26
 Re: Re: Re: Re: Taking down a silo in reply to Silo wrecker, 02-25-2004 17:52:36
Best way to take down the silo is to hire somebody to do it, so ya don't get yerself killed! RJ
Bandit
02-24-2004 17:26:32
Chip holes in the base, and crib them as you go, then build a nice fire in the cribbing, ans stand back and watch her go, watched a guy tear one down that way back home. Works pretty well, make sure your cribbing is heavy enough though. Take some good pics of it when it comes down~...
ErnieD
02-24-2004 16:56:12
Heard a guy made holes around the base of the silo, and packed holes with 2x stock. Lit the wood on fire and the silo fell as the wood burned out. Nver witnessed it.
There was a funniest home video of a silo amost falling on a fellow, he was called to lunch and it fell without warning as he walked away.
John
02-24-2004 18:04:17
 Re: Re: Taking down a silo in reply to ErnieD, 02-24-2004 16:56:12
So lets investigate this funniest home video.....
The silo fell with out any warning or any intervening by any one just as they happen to be taking a video of it; just as they happened to call the man to lunch; just as he happened to walk by it; just as he happen to be far enough away not to get hit by any falling objects.
Man you have been watching to much TV; or I need my wife to carry a video camera everywhere in case that happens to me. Can not decide which.
lenray
02-24-2004 08:32:37
Neighbors did as the others said knock some out with a big hammer then they got baCK WITH A270-30-06 type and shot out the few that it took to bring it down. I used a lot of it to build a road thru a low area easy to pick up with a loader tractor and a dump truck.
len
Delbert
02-24-2004 08:25:45
Just use a sledgehammer and start in the middle on the side you want it to fall. Keep breaking out blocks to each side and it will fall down have heard of them doing this and the silo would fall in on its self. Most of all becareful and don,t get caught under it.There will be a mell of hess to pickup but it will be down. From doing this i would let someone dig a hole and let it fall in that then cover up and replant grass less work in the long run.
ralph
02-24-2004 05:52:35
We took down a cement stave silo with a chain and a lot of cable. Broke a stave on each side fed a very good chain through and well over twice as much cable as the silo was tall. we did losen a couple of bands first. Came over easy but the debree nearly caught up to the tractor in spite of the extra long cable. be careful.
