I use the mig welder with flux wire, not gas. It's the 85 amp Farm King (or something like that) at Tractor S. Harbor Freight has em too. Comes with a 2 lb spool of wire. Kept geeting tangled up so installed the 10 lb and no problems. I am using the .035 dia wire and works for everything I do (explained later). There is a low and hi heat setting and have found nothing too thin to be welded. The tensile strength on the wire is 80,000 as I reclall (know that it is higher than a 7018 stick) so it doesn't take much to hold. I can't make a pretty weld with it but maybe if I tried harder and longer I could. Since it is for me, I don't care that much. I paid $199 I think HF has theirs for $140 which will qualify for free freight. Would get the 10 lb roll while there and be sure and get flux core; not straight wire. I have welded up to 3/8 steel on occasion but sure takes a lot of wire...but it will weld and it will hold. Usually for anything over sheet metal I use my AC DC stick and I have fallen love with the 7018 rod. Only use 3/32 or 1/8 for everything.....now that is a pretty weld. Mark
