Tool Talk Discussion Forum
What is the biggest socket set you have?
ShepFL
02-23-2004 05:37:27
I thought I was pretty well outfitted for tools. Used to work out of my tool box (Lockheed) and over the yrs. built a nice set. When I got my tractor I bought some bigger stuff (1/2" drive).
Found out this weekend I need something bigger. Had a cotter key sheer and get bound under a castlelated nut. This prevented the disk plow bottom from turning.
Using a pipewrench I got the nut off but now I can not get it re-tightened. Biggest socket I have is 2 & 1/16" in 1/2" drive. I need something like 2.5" Going by rental shop tonight to see who has what.
Just curious what tools y'all have have for the bigger stuff.
tim in wi
02-24-2004 17:21:25
 Re: What is the biggest socket set you have? in reply to ShepFL, 02-23-2004 05:37:27
1" drive sockets to 4" marked war finish sat in that rusty tool box bottom shelf used v-little but a must have
ShepFL - Thanks Ya'll!
02-24-2004 08:08:19
Some of you fellas got some BIG stuff. One day I will jump up to the BIG League. Until then this lil dog will stay off the porch! I am going to go with Brokenwrench's suggestion.
Irv
02-23-2004 19:41:58
I worked for a machine tool builder years ago. There was a large Snap On cabinet in the corner. I never saw it open until we needed to wrench on some leveling screws on a large machine we were building. The boss unlocked the cabinet - a 6 in drive rachet - the head had handles on both sides - it must have weighed 100 lbs! The sockets started out looking like small coffee cans and went up! Some of the sockets need to be lifted with the crane. The socket went on, the head went on and the handle was inserted, a tubular thing that went out about 12 feet. It was about 4 in in diameter. Only seen it used once. Irv
Brokenwrench
02-23-2004 14:37:34
Largest set I have is 1-1/2"drive set,2" up to 6",ratchet and 6" socket weighs about 50#. Before you buy/rent a socket,and if you have access to a torch, cut a box end wrench out of a piece of 1/2"or 3/4" plate. Trace the outline of the nut on the plate and torch cut it with a 6-8" "handle" sticking out on it that will fit inside a piece of 2" pipe that can be welded on as a handle. Leave about an inch of metal on the outside of the hex. This way you have the wrench when you have to retighten the gang.
jeff
02-24-2004 20:02:11
 Re: Re: What is the biggest socket set you have? in reply to Brokenwrench, 02-23-2004 14:37:34
I have got to say this is one of the best "old farmer"ways you can go. My dad did this one time and I thought he was nuts! One of the neighbors borrowed it later that year. It do work. Jeff
ShepFL
02-24-2004 08:06:09
That sounds like an idea for what I hope is an isolate incident. Me and my smoke wrench know each other well :)
Thanks!
Unimog
02-23-2004 13:26:16
My largest drive is 1" Proto with a 4 1/2" as the
largest socket in the set. I also have a few lose
sockets with an 1-1/2" drive that I use with an
adapter down to 1" drive. Biggest socket is 6-1/2
and it weighs around 25 lbs.
Gary
02-23-2004 12:31:07
Had 1" drive set that went to 5" socket but sold it to a construction company. Also had a 1" air impact but sold it to a tire shop for trucks.
VADAVE
02-23-2004 11:01:43
Just rebuilt my disc. Used a Harbor Freight 3/4" drive set with a set of Jumbo sockets. Had to buy a breaker bar from Craftsman and turned it with a 4' pipe. Got the nut as tight as I wanted without much effort at all.
OH yeah a pipe wrench on the other end to hold the shaft from turning.
Ken
02-23-2004 09:39:17
Whatever tools you buy , remember those foreign countries don't feed our people . But us dumb Americans continually feed them by buying their junk . Think about where our jobs are going . Buy " American " made products . I'm proud to be an American . And proud to say I don't buy foreign made junk . Ken
Pitch
02-23-2004 15:26:53
 Re: Re: What is the biggest socket set you have? in reply to Ken, 02-23-2004 09:39:17
So Ken Did you spend 400.00 on an American 3/4" drive socket set that you are going to use for an hour a year? I suppose that you don't watch TV or listen to stereo either. Stupid for most of us would be spending that kind of money for a low use item. I spent 50.00 bocks on a Chinese set then spent the other 350.00 buying American groceries for my American family.
Irv
02-23-2004 19:31:57
 Re: Re: Re: What is the biggest socket set you hav in reply to Pitch, 02-23-2004 15:26:53
Well, I bought the American 3/4 drive socket set. If you don't like American made tools, don't buy them. I understand your thought on economy, but I respect Ken's ideas more. My 2c irv.
george md
02-23-2004 09:39:16
Shep,
I have most of a set of inch and a half
drive set and an air wrench to turn them and have 1 inch and 3/4 as well. 1 & 1/2 gun really likes air . :-)
george
Gary in Geneva
02-23-2004 09:24:36
I only have an occasional need for something over 1� (Large truck and a MF 40B tractor) so I purchased a �� drive set from Harbor Freight for about $40.00. They cover 7/8 � 2� with extensions, ratchet and breaker bar. Later I needed a 2 �� socket and purchased the jumbo socket set to take me up to the 2 �� size I needed.
I will admit they are big and clunky and the ratchet is DEFINATLY not persion, but they have held up to several sessions of wrenching, including a 48� cheater pipe with me bouncing on the end to break some stuff free.
I have a store within 20 miles so that I can look at what I am buying. I have generally found anything that needs lots of steel and not much precision (big wrenches, hammers, sockets, jack stands, etc) to be quite useable. The rest of the stuff you need to know what to look for and choose carefully.
old
02-23-2004 09:09:14
I have a 3/4 drive set with sockets up to 3-1/2 inch and I also have a wrench set that goes from 1/4 up to 2-1/2 inch. I don't use the bigger one offten but boy its nice to have them when you need them. I also have a big compresser and a 450lbs torque impact gun.
Jerry B
02-23-2004 06:17:59
Farmered is correct. 1/2" drive will not handle anything much over 2-1/4.
You won't necassarily need a Snap On set of 3/4 drive sockets. Craftsman tools are fine, but if you know you won't be using them a great deal, then a China made set will work fine. I have such a set and have been using them for years. Never broke a socket yet.
Farmered
02-23-2004 05:45:01
Rent a 3/4 drive set. 2 1/2 is too big for a 1/2 drive and you will end up breaking your handle. Ed
Brian G. NY
02-23-2004 08:03:06
 Re: Re: What is the biggest socket set you have? in reply to Farmered, 02-23-2004 05:45:01
I'm with Jerry; bought a Taiwan 3/4" drive set about 12 years ago for $40. I don't need them a lot and they're probably a bit "clunkier" than "Snap-ons" but they do serve the purpose. It didn't come with a breaker bar, but a piece of 1-1/4" pipe fits the handle real nice and I haven't broke the handle or a socket yet.
Catskill Pete
02-23-2004 16:30:28
 Re: Re: Re: What is the biggest socket set you hav in reply to Brian G. NY, 02-23-2004 08:03:06
I almost hate to say it but I have a 3/4 Snap On set[shop] and a cheap HF set [truck] and for the amount I use them I can't really see any difference. IHMO
Stick
02-25-2004 20:35:39
 Re: Re: Re: Re: What is the biggest socket set you in reply to Catskill Pete, 02-23-2004 16:30:28
Me too. I have a Snap-On 1�" set at work and an el cheapo 1" set at home. For what I need it for at home, the cheap crap works. Oh, at work, we have up to 18" sockets with up to 4" drive and slugging wrenches up to 24". Some special wrenches up to about 4' across. Torque multipliers up to somewhere around 6000 lbs-ft, etc.....I'm an operator/millwright in a hydro-electric generating station.
