Tool Talk Discussion Forum
Barn Moving Ideas?
Hound
02-23-2004 05:20:30
My neighbor sold his dairy herd, and told me he's going to level his pole barns. He has 2 that are approx. 40x80 each. I was going to build a shed roughly that size here, myself. I was wondering if anybody had ideas on how to move them over here(across the road) They have about 10' of head room in them. My idea so far was to take the steel off the roof every 30', cut all the trusses, back my big bale wagon (capable of massive loads) underneath, with a row of square bales down each side, jack building up, set on bales, and pull over in sections. the next problem is that I want 16-18' of "head room". How can I lift/jack up the roof to that height? any ideas would be helpful, I would hate to see them get hit by a match. Thanks.
jls
02-23-2004 20:13:51
 Re: Barn Moving Ideas? in reply to Hound, 02-23-2004 05:20:30
moved a couple of smaller(24 x32) pole barn types. did it like morton does their barns. set a pole sticking out of the ground 6' and bolt the old barn to that. the problem I see with a big one is getting your headers under the trusses straight so the roof doesn't look like a snake. second prob. is weight will crush your hay bales, slightly twisting the roof sections, that can pop nails and make leaks. hate to agree with the nay sayers but complete dissasembly might be better in the long run, rent a teleporter and use it as a portable scaffold to saws-all roofing metal and purlin nails from underneath and lift trusses off get lots of bi metal blades, pole barn nails are hard!
bob
02-23-2004 20:13:50
we move'em by bolting skids to poles, then cut poles off, so they can be skidded by putting dozer on each end & pulling together, slide it to new spot.
Bill Smith
02-23-2004 11:45:38
I agree with butcher. You would be better off doing something different. Framed buildings can be jacked up, moved, and set on new foundation fairly easy. Pole building is a hole nother story. Doing what you want to do (make it a taller building), forget it. You will have to buy all new poles and set them all anyways. You won't be saving absolutely nothing on the poles. That only leaves rafters, siding, and roofing you will be salvaging by moving. If there is something there to salvage like siding, rafters, roof tin, and so on, go over there and tear it down and then use the useable stuff in constructing a building from scratch at your place. If you really look at a great big pole shed, there really isn't to much to salvage. The old poles, plan on cutting them off at ground level, what's left is what's left. If it has shingels on the roof, about the only thing worth salvageing is the rafters out of the roof and if they are made from 2x4's or short you really aren't salvaging anything there. And as far as using second hand tin, you just about got to use it the second time as siding because of the holes in it (likely leak if used on roof). Well, anyways you can kind of see what I'm getting at. But hey, if there is material in it that you can use to build yours, by all means go over there and tear it down for salvage. I just don't know what in particular there is there to salvage as far as lumber, tin, and what not.
Butcher
02-23-2004 10:41:14
It can be done but it's alot more complicated than you may think. The projects that I have been involed with required ALOT of bracing, steel I beams,and alot of man hours. Not to mention the crane and operator at $100. per hour. You have to remember that depending on where you live those pole could be in the ground almost 4 feet. Not only that but getting it up another 6 to 8 feet would require scabing new poles to the sides of the old ones. I dont mean to rain on your parade but,if you dont want to build new, I would consider disassemly, salvage what you can and go from there. Still no easy task.
