Tool Talk Discussion Forum
What are crowsfoot wrenches for?
Jim A.
02-22-2004 19:25:45
These are the little open-end wrench that attach to a 3/8" drive. The only thing that I can think of is that they are for using a torque wrench on somthing that you can't get a socket on. If this is the case, how dose the extra length affect the torque reading?
Craig (GA)
02-24-2004 14:22:55
 Re: What are crowsfoot wrenches for? in reply to Jim A., 02-22-2004 19:25:45
Well, crowsfoot wrenches work well in hard to reach areas using an extension. I can attest to their use on tightening the auto. trans lines on a 65 el camino...they are occasional use tools. You could use them on a torque wrench I suppose. The extra length could affect torque reading (if you were using a 4 ft extension or something). It will have an effect on shorter extensions as well. Generally, 3/8" drive extensions are heat treated resulting in a brittle and strong material; they don't have too much deflection in torsion before they will fail (break). The chrome finish on extensions has a purpose other than being pretty. Depending on thickness (often not very) it could increase the strength of the extension material (minimal). The toughness of the chrome prevents damage to the underlying material. If you drop an extension (unchromed) and a mark was made in it's side, then you have just created a small stress concentration (place for potential failure). The chrome helps to prevent this due to hardness. Well, that was more info than anyone wanted to know.
Paul Janke
02-24-2004 10:07:19
When you need one, you won't have to ask what they are for. You'll just wish you had it.
buickanddeere
02-23-2004 05:35:26
Using a crows foot wrench with the torque wrench at a 90 degree angle doesn't affect the torque value on the wrench. Having the crows foot inline with the torque wrench handle increases leverage and overtorques the fastener.
Van in AR
02-25-2004 05:09:45
 Re: Re: What are crowsfoot wrenches for? in reply to buickanddeere , 02-23-2004 05:35:26
It will overtorque the fastener if you dont use the formula to convert it down to the right torque. The wrench is turned down a bit to compensate for the longer 180* addition.
Van
John
02-23-2004 02:59:02
Think of a crowsfoot this way. It is a 1 inch long wrench to get in tight spots. Since you can not get your hand into this small spot and would have no leverage on a 1 inch wrench if you could it has a hole in it to put a extension and ratchet so you can turn this 1 inch wrench.
ShepFL
02-23-2004 05:31:04
 Re: Re: What are crowsfoot wrenches for? in reply to John, 02-23-2004 02:59:02
Ditto -
I have 2 sets up to 1.5 inches. One is std. open end wrench style and the other is 12pt open socket style. Used them when I turned wrenches on aircraft. Used std. open end wrench style mainly to install bolts on rear of equipment racks and the open socket style for hydraulic lines.
Wayne
02-22-2004 20:09:57
Oleblu hit the nail on the head when he said, crows foot wrenches are mainly used to go where other wrenches won't. One of the common places I use them is removing hydraulic lines off valve blocks. Many times there is only room around where the line attaches for the length of a crowsfoot but there is plenty of room to swing a rachet if you go up several inches with an extension. I also have a 1/2 drive set up to 2 1/2 that I keep instead of having to carry several wrenches that size. Usually the only thing your gonna be taking apart, by hand, that's this big is a hydraulic line and in that case a crowsfoot with a long rachet or pull handle does the job perfectly and saves alot of weight and space over similar size wrenches. As far as using them for torquing things, it will effect the torque. The amount of difference it makes will be dependent on the distance from the center line of the bolt being torqued and the center line of the square drive hole which will normally be different depending on not only what size, but also what brand crowsfoot your using. Hope this helps explain it some.
oleblu
02-22-2004 19:46:37
I've used crowsfoot wrenches to loosen/tighten power steering lines and fittings on the rack and pinnion cars. I've also tightened the valve stem nut on the inside dual on a semi without taking off the outside tire. This only works on the steel wheels with brass stems. Sometimes they just go where no other wrench will go. oleblu
