Tool Talk Discussion Forum
Wet sand blasting. Affective? or not affective?
JD Fever
02-21-2004 16:06:16
Has anybody ever wet sand blated their tractors? Is this method of sanding affective or inaffective?
Thanks,
JD Fever
Bill Smith
02-22-2004 11:54:36
 Re: Wet sand blasting. Affective? or not affective in reply to JD Fever, 02-21-2004 16:06:16
Never tried wet sand blasting, but have done a bunch of dry. Had trouble with condensation filter getting full. Moisture would show up in the air flow. My experience when this happened was immediate rusting. I would have to change condensation filter, and lightly re-sand blast again. My goal was to not paint over any rust. I did notice that even a dry sand blasted peice would rust over time just from humidity in the air. I would try to atleast get a coat of primer on as soon as possible after sand blasting.
Dale B.
02-22-2004 10:55:17
I did the sheet metal on my Oliver 70 with one , and was very pleased with it. I did it on a hot day, and blew the water off with an air hose to minimize flash rusting . I primed it that day, and have had no problems with the paintjob. The dust from dry blasting is such a hazard !!!
Jason
02-22-2004 06:02:52
I did my JD A rear wheels with it once. I'll never ever do it again. The wheels are round spokes and it was a mess trying to get all of the rust off before you paint. It cleaned them up nice untill the rust came back. I just don't see the point in removing rust then putting it back on again so you can remove it one more time. I'll put up with dust with the regular sand blaster.
carpenter
02-21-2004 21:08:13
JD Fever, Ihave a 4 gallon per minute pressure washer with up to 3600 pounds of presure. I have removed all the paint on the sheat metel and rims of two tracrtors the last one my 730D. I am able to buy sand locally by the pallet. I think I bought 4500 hundred pounds for $115.00. I am thrilled with mine. I felt it was fast and clean. The rust is easily handle by wiping with acid. I can't remember what kind I used but The rust is removed about as fast as you can wipe. I think this is similer to etching primer. I love mine.
raytasch
02-21-2004 17:37:30
I have used mine twice. It works well for small jobs. It does use a lot of sand. I would not want to do a large job with it. I am pleased with it. As mentioned below, flash rust can be a problem. I use Ospho to stop the flash rust. ray
rhudson
02-21-2004 16:50:26
my experience with it is that the metal rust as soon as you move the blaster nozzle to another spot.
