Tool Talk Discussion Forum
Value of Low-E insulation in a Pole Barn
IH230
02-19-2004 14:24:35
In a new pole barn (40' x 60') used as both a shop & machine storage is "Low-E" (foil, bubble bubble white polyethylene) insulation between the roof purlins and the metal roofing worth the approx. $1000 cost in southeast Missouri? Is it worthwhile on the walls as well?
Thanks in advance for your feedback.
Nate in IA.
02-20-2004 13:18:31
 Re: Value of Low-E insulation in a Pole Barn in reply to IH230, 02-19-2004 14:24:35
You sure do want it. I sell here all the time. We use it in open livestock barns, machine sheds and on the side of homes. If you put the silver side out you have a R-7 -10 all year around. It works onboth condensation and insulation. If you want to hear more E-mail me.
Dieselrider
02-19-2004 16:52:00
One thing to consider if you are using the metal roofing. If you decide not to use the bubble wrap, you should consider something under the metal like house wrap or the like, as it really helps stop the condensation dripping on all your equipment inside. On a cold morning the metal picks up dew and when the sun hits the outside the inside "pees" on your tractor. Just my 2 cents.
old
02-19-2004 16:32:51
Well no if you never want to heat it but yes if you do. So you also live in Missouri.
