Tool Talk Discussion Forum
welder leads
Howard
02-19-2004 11:46:53
I have the chance to buy an older lincon welder gen set with 225 dc amp with the 25 amp fine adjustment and 50% duty cycle with wiscounson engin it needs a good cleaning and some screws but does not burn oil and stars right up how ever it needs cables and stinger and ground clamp and 1 moor 12 volt battery how much can i exspect to pay for the things and in said condition what is a fair price for somthing like that thanks Howard
Fred OH
02-20-2004 12:41:41
 Re: welder leads in reply to Howard, 02-19-2004 11:46:53
Very first thing to do is to pull the end cover off and look inside of the cover and see if it has slung any solder...if it hasn't then look at the brushes and commutator...if they look okay and the general appearance says okay and it runs good...take a chance on it for the quoted $200. But, get a stipulation that as soon as you get leads for it and try it out...you have a bring back privelege...so you will still be friends. Fred OH
Howard
02-20-2004 04:25:46
thanks guys it is from a good frend who has used it on a job site and said its good .But some body releaved the cables off of the job site it is $200 and what it will cost me to replace the cables thanks Howard.
TimV
02-20-2004 08:46:45
 Re: Re: welder leads in reply to Howard, 02-20-2004 04:25:46
Howard: $200 sounds like a bargain--while the Wisconsin engines are rather expensive to repair, they are a decent setup if they're running right. You should be able to get the leads for less than $100 complete with stinger and ground clamp. This would give you about $300-400 in the whole setup, which is quite reasonable for a generator/welder combo.
Slowpoke
02-19-2004 22:51:07
Where are the cables, clamp, etc? Anytime a seller say "I don't know where that part is", something is fishy. Try to borrow a set of cables to test the welder before purchase.
Bundy
02-19-2004 19:49:28
I dont know if you know and trust this person you are going to buy from. But i would not pay alot for a welder that i could not test weld with before purchase. just tring to help.
old
02-19-2004 14:00:39
Cables will run any where from 1/2 dollar up to around $2 a foot depending on what you get, the longer the heavyer you will need, as far as the battery I'd use a car battery so around $40. I payed $250 for one a few years ago and the engine was locked up so I'd say any where from there up to around $2000 depending on age etc.
