Tires
Dusty
08-27-2000 17:31:36
If other people have had the same luck that I have had with Michelin light truck tires that I have had, there would be a recall on them. Michelin will not warranty them.
Dusty
raytasch
08-29-2000 16:46:36
 Re: Tires in reply to Dusty, 08-27-2000 17:31:36
Dusty, I have about 60,000 miles on 6 Michelin Lt235 85 16 s. They still have half the tread left and are wearing perfect. They will probably rot off before they wear out. BTW, I run at 16,000 lbs all the time. ray
M.R.
08-29-2000 10:39:37
We've have really good luck with the Toyo M-55 thru Les Schwab.
The largest percentage of our driving is on gravel, there-fore, we prefer a tire without-or with very few snipes.
Larry(SD)
09-09-2000 17:33:59
 Re: Re: Tires in reply to M.R., 08-29-2000 10:39:37
Dusty:
Please educate me as to the meaning of "snipes" as pertaining to a tire.
Thanks in advance.
Dick L
08-28-2000 19:48:51
Sorry you have had bad luck with Michelin tires. I have only had Michelin tires on my last four cars and have not failed to get over 80,000 miles per set except for one tire that I hit a curb with on ice. Normal driving milage is 45 to 50,000 miles per year.
Nathan(GA)
08-28-2000 10:56:11
Dusty, A friend uses them on his Ranger. He got 83,000 out of the last set of LTX M/S. We just put a set of them on my wifes Explorer, 5,000 miles ago. We replaced the Firestones that are recalled. Believe it or not, they had 65,000 on them and a good bit of tread left, but began dipping out on the edges. No matter what brand you use, rotation is the life of a tire. I rotate every 5,000 miles. I got 67,000 out of the last set of Bridgestone mud tires on a 4x4. They are still suitable for a trailer.
Steve U.S. Alloys
08-28-2000 05:35:58
I have Uniroyals on my road car. About 1/3 of the miles are city driving. The rest highway. I'm replacing the front tires today before a long trip. The tires have 63,000 miles on them and would still be OK for trailer tires. The back tires look real good still. (Front wheel drive vehicle.)
The best luck I ever had with tires were Bridgestones. I got 95,000 miles out of a set. At the time, I was logging about 34,000 miles a year of concrete sailing. Those came on a Toyota with a four cylinder engine that I put 195,000 miles on.
One of my customers wanted to buy the car if I ever sold it. When that day came, I told him I didn't want anybody mad at me over an old used car, so, the understanding was, if it broke in two going down the driveway, he owned both halves. He put 35,000 more miles on it and then got "T-Boned" in an intersection. End of story for Tojo.
The Red
08-28-2000 04:27:46
You didn't specify your problem. We had Michelin LTs on Mrs. Red's Jimmy. The 80,000 mile rated tires only made it to 40,000. Tread wear was terrible. I replaced with Goodyear Wrangler LTs.
Burrhead--Hello Mr Depity Mayer
08-28-2000 18:22:46
 Re: Re: Tires in reply to The Red, 08-28-2000 04:27:46
I had a set of them high $ things put on Ma Burr's Ranger time before last. On the 80,000 mile the 1st bad one started dishing out at 17,000. The last one made it to 38,000. With the pro-rata warranty it would cost as much to get them replaced than she had originally paid for them.
She always gets the lifetime balance and rotation deal so they were rotated and balanced at from 4500 to 5000 miles and they were still trash tires.
I replaced them with the cheapest Cooper tire they had and so far they've run 40,000 and still look good.
On my truck I ran a set of the Firestone Wilderness for over 70,000 and then put them on a trailer. The only trouble I had was that I hit a piece of steel in the road and cut one in two.
I'm trying out a set of Kuhmo on my sons pick up. They have about 25,000 and still look good. If he can't tear them up or spin them slick pretty quick I'll put them on mine next time, they're alot cheaper and are a all position traction lug tire.
The Red
08-29-2000 07:43:08
 Re: Re: Re: Tires in reply to Burrhead--Hello Mr Depity Mayer, 08-28-2000 18:22:46
I might add that the Michelons were OEM. I wish I had immediately driven that Jimmy to Goodyear and traded them on the spot. I have used Wranglers on the last 2 Jimmys and 2 pickups with good results.
Burrhead
08-29-2000 08:37:29
 Re: Re: Re: Re: Tires in reply to The Red, 08-29-2000 07:43:08
I'll have to check it out Red. Is the Wrangler a lug type tire?
I don't like mud grips but I do like the square lug type all position tires.
The Red
08-29-2000 10:15:02
 Re: Re: Re: Re: Re: Tires in reply to Burrhead, 08-29-2000 08:37:29
I am afraid not Burrhead. Just your typical mud and snow type of tread. Goodyear has the nobby type of tires but I don't know the name of them.
Larry Garbarek
08-29-2000 14:46:24
 Re: Re: Re: Re: Re: Re: Tires in reply to The Red, 08-29-2000 10:15:02
Try visiting websites for various tire manufacturers.
The chain stores here (Wal-Mart, Costco and others) had various tires on sale for around $55 each for my Sienna. They also had tires for $100 each.
That seems to a quite a spread and I was not sure which way to lean.
The chains had 2 or 3 tires to choose from. A local independent shop that has served our community for almost 100 years had hundreds of options to choose from and suggested a different tire based on his experience indicating that it was a "good fit" for my car.
He wanted $12 per tire more than the cheapest for this "good fit" for a model of General brand not carried by the chain stores.
General had both the cheapest at $55 and the "good fit" at $67.
Both the $55 and $67 tires happened to be General Tires. I checked out the Continential/General website and found that they did not recommend the $55 for my car but they recommended the $67 as being the best fit for my car and my driving needs.
I'll be buying the "good fit" tires before the end of summer as I am more confident I will be satisified with the $67 over the cheapest.
So, do some surfing. I found a lot of information on the internet....maybe too much, but, I think I am making a more informed decision after doing some research.
Burrhead--10-4 (nm)
08-29-2000 12:58:27
