Tool Talk Discussion Forum
aftermarket powersteering
Pat Walsh
02-17-2004 18:12:19
Have added a Eaton Sharlynn pump to my Massey Harris 44 to give it power steering. I am trying to run this with a chevy powersteering pump, with no luck. Need 1000psi and 3 gal a minute to run. From what I have been told, I am not getting enough pressure from my chevy pump. Any ideas what I could you to run sharlynn pump.
jed
02-18-2004 05:46:50
 Re: aftermarket powersteering in reply to Pat Walsh, 02-17-2004 18:12:19
I have a Chevy pump on my M and it runs it fine.
Pat Walsh
02-19-2004 16:59:14
 Re: Re: aftermarket powersteering in reply to jed, 02-18-2004 05:46:50
Was wondering if you used the stock pulley or put a smaller one on to get more rpm's.
Thanks
Pat
Joe (Wa)
02-17-2004 20:17:35
Are you using the Char-lynn torque motor (p/n 217-1015 is typical) that mounts in the steering shaft? Chevy pump should run it ok. The pressure on my Case 311b w/loader runs 150-500 psi normal driving. You can check out the motor with a temporary hookup to the tractor hydraulics, just keep the pressure 1000 psi or less. Joe
ralph
02-17-2004 20:12:39
We run the same combination on IHC M, however you will probably need a larger oil tank as the oil could be getting to hot. Once in a while the pressure relief valve will stick on the chev pump and cause a los of pressure. We added a larger seprate tank and that did the trick. On another simuliar conversion we used a truck pump to get more oil capacity.
Ray,IN
02-17-2004 18:58:47
Perhaps you'll find some answers here:
