Tool Talk Discussion Forum
Dwell-tach
Carol Martin
02-16-2004 15:21:11
Hi: I am looking for some information on a Montgomery Ward Dwell-Tach/Volt-amp/points Meter. I picked this unit up at an auction everything seems to be there except the Instructions. Maybe someone has one ? The model is 9660 There is one cord that has three leads Black Red and Blue The other cord seems strange to me.. it has two leads red and black going to a metal strap with both leads Riveted on to it and is direct shorted There is also a 0.2Ohm Resitor that looks like it is made to attach to the metal plate. The selector switch has the following positions. Points, Volts, Amps,High rpm 0-8000,Low rpm 0-1200 and Dwell. Also has switches for 6/8 Cyl and 6/12 Volts. If you have any Info on this I would appreciate it.
I have several old tractors and this would be nice to use on them if I can figure out how to hook it up..
Thanks
Carol Martin
Hermit
02-16-2004 17:58:52
 Re: Dwell-tach in reply to Carol Martin, 02-16-2004 15:21:11
My guess - black,ground - red,battery - blue, negative side of coil. The other red/black leads sound like the ammeter leads with the resistor as the shunt that allows the ammeter to work.
Craig
02-16-2004 18:19:07
 Re: Re: Dwell-tach in reply to Hermit, 02-16-2004 17:58:52
Hermit is correct. i have the same machine but it is labeled as a Craftsman. I have never used the ammeter feature, only the tach.
Carol Martin
02-16-2004 19:24:08
 Re: Re: Re: Dwell-tach in reply to Craig, 02-16-2004 18:19:07
Craig: Do you happen to have the instruction booklet or sheet?. If so could I get you to make me a copy?.
Carol
Craig
02-17-2004 12:43:39
 Re: Re: Re: Re: Dwell-tach in reply to Carol Martin, 02-16-2004 19:24:08
yes, i do believe i have the instruction booklet. Unfortunatly, all of the stuff is not at my house right now (it's at my cabin) i will be able to get it in about 2 weeks though. can you wait that long, or are you in a hurry?
if your in a hurry, i can tell you how to use the tach and dwell, but i don't know anything about the ammeter.
Carol Martin
02-17-2004 13:23:46
 Re: Re: Re: Re: Re: Dwell-tach in reply to Craig, 02-17-2004 12:43:39
Hi Craig:
no not in a big hurry just have the unit so would be nice to have the instructions. If you get a chance I would love to have a copy. Drop me an E-mail and I will send my Address. Will be glad to pay for copying and mailing..
Carol
Craig
02-17-2004 16:33:14
 Re: Re: Re: Re: Re: Re: Dwell-tach in reply to Carol Martin, 02-17-2004 13:23:46
Is it ok if i just scan them and send them as an attachment to an e-mail, or would you prefer that i mail you a real copy?
Carol Martn
02-17-2004 18:20:05
 Re: Re: Re: Re: Re: Re: Re: Dwell-tach in reply to Craig, 02-17-2004 16:33:14
Craig. Scanning would be fine. Much appreciate your help.
Carol
