Tool Talk Discussion Forum
12V Switching Valve
TomH
02-16-2004 09:48:14
I'm probably OT but I need some advice/help. I would like to remove the manual valve that controls the "hot water" which run into the cab heater on my CASE 580. In its place I would like to plumb in a 12V switch activated valve. Where I can get something like this?
Thanks for your help!
Red Dave
02-16-2004 09:59:21
 Re: 12V Switching Valve in reply to TomH, 02-16-2004 09:48:14
What you want is a 12 volt DC Solenoid operated valve.
This place has a lot of solenoid valves, do a search, you may find one that will work for you.
arthur
02-16-2004 20:53:28
 Re: Re: 12V Switching Valve in reply to Red Dave, 02-16-2004 09:59:21
ASCO solinoid valves from a plumbing supply house come in many pipe sizes and coil voltages AC OR DC 12v TO 240v AC and 12v 24vDC you buy the valve and the coil you want grainger have them listed in there book not cheap parts are also availabl there
greenbeanman
02-16-2004 12:06:36
A sprayer valve will work if it can withstand the heat of the coolant going through it. Many or most have PVC valve bodies. Not sure if all PVC will handle heat, but you used to have to use CPVC.
