Tool Talk Discussion Forum
Oxygen Acetylene cylinder tank pressure
Mac(TX)
02-13-2004 17:45:44
What is the normal tank pressure I should see on my exchanged tanks from the welding supply store?
I remember some years ago the oxy tank would read about 2200 psi and the acet tank about 250. Recently the tanks are oxy 1500 psi and acet 150 psi.
Is this a new standard are am I getting cheated?
Mac(TX)
02-15-2004 19:25:53
 Re: Oxygen Acetylene cylinder tank pressure in reply to Mac(TX), 02-13-2004 17:45:44
Thanks everone for their replys. With this information I am going back to the supplier for compensation of some sort.
T_Bone
02-15-2004 18:22:57
Hi Mac,
The cylinders are supposed to be 2200psi@70� for O2 and 250psi@70� for Acetylene.
But there's another law that states Acetylene pressure can not exceed 250psi for storage. That means a Acetylene cyl in the sun at 130� can not exceed 250spi. Then a Acetylene cyl at 70� would have a pressure of 223psi and be full.
I did not find a law that stated a maximum pressure for o2, so at 130� a o2 cylinder would have 2450psi.
I've also noticed that here my cylinders filled pressures were getting lower. Just not as low as you said. I did change my gas supplier this last fill and my cylinders now run 2000psi and 200psi and a lot better than before but I still feel there low numbers.
T_Bone
Tank exchange..John,PA
02-14-2004 08:41:18
In the refrigeration business, we use smaller tanks. "B" and "R" and we just exchange them for full ones.
As soon as I get the new tanks into my van, I check the pressures. So many times we find "leakers" and the new tanks are empty. This is very costly when we get to a job site, and we are already out of gas. Plus the nearest supply store is 30 miles away.
ShepFL
02-13-2004 21:28:37
Hate to say it Mac but it sounds like the gas company is jipping you. Check to see if they gave you a lower bill but I doubt it. The supplier decided they no longer wanted to deal with individuals and I am sure this was part of their strategy.
What I ended up doing was taking my tanks to the local welding shop and had them get my tanks filled. I get a better price and if any issues he raises cane. I just make sure I take him some business from time to time and send others his way, plus I pay him $5.00 extra for every tank I get filled.
I am sure he is making something more than this from others I have referred his way but $5 is cheaper than the gas I was paying for and NOT GETTING.
Wayne
02-13-2004 20:20:05
Hey Mac, sounds to me like your being cheated on both bottles. I know the oxy and acet are sold by volume/ weight, so the pressure isn't always an indication that something is wrong. Still 80 cuft of gas in a cylinder of a certain size should always weigh the same, with the only difference being a slight difference in pressure depending on the ambient temp. Filling one of these tanks is basically the same as filling a propane tank. I don't ever remember getting a new oxy tank with a pressure lower than 2100, and I have seen a few as high as 2600. Acet the same way, normally around 225 to 250. If I were you I'd be changing suppliers and/ or demanding a refund.
Buck
02-13-2004 18:56:52
Just got mine filled. oxygen 2200, acetylene 200.
