Tool Talk Discussion Forum
Sand blaster
Larry806
02-13-2004 09:59:32
third party image
Last guy that borrowed mine said to send him a bill for it I made this one to replace it. This is the 6th or 7th I've made The hose isn't on it yet. That is a air tank from a semi. A 2" pipe nipple welded in the top The bottom pipe is 1 in nipple welded in 1" quater turn valve on that 1/2" pipe for air This is a pressure tank with a purge valve in the air line
wdTom
02-15-2004 18:08:41
 Re: Sand blaster in reply to Larry806, 02-13-2004 09:59:32
Hey Larry, does a pressure blaster work like it looks? Air supply to the bottom pressureizes tank, then sand just runs out the bottom valve into the air line to the nozzle. In other words the 1/4 turn valve regulates the sand into the air stream. Have heard pressure blasters work better than the siphon blasters like I have. As I have a couple of air tanks like you used, which I like, being narrow woun't take up much room, it might be a good time for another project.
Larry806
02-13-2004 10:07:00
third party image
This is the top I use a funnel to fill it Put a 2" pipe cap on to seal it small valve is to bleed off pres. when you shut it off
VaTom
02-13-2004 10:33:36
 Re: Re: Sand blaster in reply to Larry806, 02-13-2004 10:07:00
Hi Larry,
Looks similar to mine from Harbor Freight but I hope you used better valves. What are you doing for a nozzle?
Jerry
02-13-2004 16:39:46
 Re: Re: Re: Sand blaster in reply to VaTom, 02-13-2004 10:33:36
I have a TIP blaster and it has been trouble free. I cover my lens with saran wrap to avoid buying new all the time.
