Tool Talk Discussion Forum
air compressor parts
Mike
02-11-2004 13:52:53
so my compressor burnd down this weekend and I bought a used one to use till a new one gets here..
The used one needs new "reed" valves? putin some used ones that came with it to get it pumping...Questions is where can I buy these for the following machine?? 4 cylinder, PARCORP, Model 20 FM, Serial AM1697 made by Lynch Mfg of Defiance Ohio. This was all take off a tag..older machine but like it well enough to want to fix.
Please e-mail [email protected] with any info/help/appreciated.
thanks
Vinnie
02-13-2004 05:57:53
 Re: air compressor parts in reply to Mike, 02-11-2004 13:52:53
I have used Green Valley Compressor in Texas for hard to find compressor parts. I don't have a number, but I'm sure you can find them on the web.
Phil9N
02-12-2004 19:12:20
Yo Mike. Sorry to hear about your bad luck. If you need more reed valves,sometimes you can use thin feeler gauges like us mechanics use to set valves etc. If they're the right width and thickness, trim to the desired length and this will get you out of a bind. Good luck.
mike
02-13-2004 05:34:27
 Re: Re: air compressor parts in reply to Phil9N, 02-12-2004 19:12:20
thanks..tried that, it worked for the smaller ports but not the larger ones..figure there must be someplace out there that still has them..
Went and bought a new 7.5 hp compressor yesterday, but still need to fix this old one for resale
