Leaking gas solenoid on MIG welder?
Leon
08-21-2000 10:42:12
I went to use my Miller MIG unit this weekend and noticed that the weld was really bad because I was out of argon.
I thought I had looked at the gauge pretty recently and it showed that I had a fair amount of pressure left.
So- I am wondering if my solenoid gas valve may be leaking. How likely is this on a 4 year old MIG welder? Are there any things that can cause it to stick open that I should avoid? When I replenish my gas, how should I test to see if it is closing properly?
This all may be hysteria on my part- it probably just ran out of gas, but it just seems kinda sudden.
Greg
08-21-2000 14:16:11
 Re: Leaking gas solenoid on MIG welder? in reply to Leon, 08-21-2000 10:42:12
I believe the the valves on all the inert-gas cylinders have double seats, they need to be opened / closed all the way.
Have you tried pressuring the guage to say 30 Lbs. or so, shutting the valve and running a leak-down check? If excessive may also try a soapy mixture on all the fittings. My own will still holding within 5-10 lbs. after aprox. 15 years, in a half week period, when I forget, which has happened.
G
08-21-2000 14:22:30
 Re: Re: Leaking gas solenoid on MIG welder? in reply to Greg, 08-21-2000 14:16:11
when I forget, [to back the guage off]
