Tool Talk Discussion Forum
Wire tracers
Wayne
02-07-2004 22:59:24
Hey guys, I'm looking for a wire tracer/tracker that is usable on a single wire in an open/unpowered circuit. Basically I often get calls to fix or repair butchered wiring on old equipment. I very rarely have a wiring diagram to go by, and many times the main part of the harness is still intact. Usually a total rewire isn't necessary, thankfully, for that reason. Also there is usually no OEM harness available anymore, and hand making one really isn't feasible do because of it's complexity, unless there is just no alternative. In those cases if I could track where each wire was going in the old harness and make splices or reconnect existing connections when needed, it would save me alot of headachs, and the customer alot of money on the labor of a complete rewire. I have seen the one Northern Tool carries made by Gardner Bender and I know it's inexpensive (about $40) and according to the Mfg is capable of doing what I am wanting to do with it. I have also seen several models made by Amprobe that will do all I want and more starting in the $200 range and going up from there. My question is have any of ya'll ever used any type of tracker/tracer that is usable on a single wire, open circuit, and if so what do you know of anybody else making this type of tool, or have you had any experience with the tools GB or Amprobe I just mentioned. I'm a heavy equipment mechanic who just happens to be pretty good with equipment wiring so I get a good bit of this type work, but it isn't what pays the bills if you know what I mean. What I want a unit that is gonna do what I want for a reasonable price, but not break the bank and never be able to pay for itself with it's usefulness. I know you get what yuo pay for, and I don't want junk, just a good meduim grade tool. Thanks for any help you can offer. Wayne
T_Bone
02-08-2004 22:20:26
 Re: Wire tracers in reply to Wayne, 02-07-2004 22:59:24
Hi Wayne,
Radio Shack builds a cheap tone tracer for about $30.
You can also make your own with a 9vdc battery, electronic buzzer and a couple aligator test leads. All from RS.
Then you can also use a VOM. I like the analog ohm meters for this type of work.
T_Bone
Wayne
02-09-2004 21:09:49
 Re: Re: Wire tracers in reply to T_Bone, 02-08-2004 22:20:26
Hey T_Bone, I have been doing bsically what your talking about for a while now to trace wires. I usually just disconect the battery hot leg and tie it direct to the wire in question and take my meter and start looking for the juice. Problem is this can take a while sometimes because with a harness full of wires branching in a dozen different directions I don't always know which direction to hit first to find the one with power on it. Not to mention if it happens to be grounded it pretty much makes this way impossible. For this I made myself a set of 15" leads so I can leave the meter in the center and cover nearly 30 feet with it set up to give a tone when I complete the circuit. This works too, but again is a real pain for the same reason. With the tracer like I want it puts a tone in the wire that can be picked up all along the path of the wire, not just at the terminations, and that makes it alot easier to trace. Also with the tone in the wire you can find a break alot easier because the tone will carry as far as the break,and stop. So as long as you can trace the wire with a tone you know it's good, but when the tone stops you know you've found your break. I did some more looking today and have found a few that look pretty good in the $300 range which isn't bad. The first ones I had found were closer to $600 which was alot more than I wanted to spend.
T_Bone
02-10-2004 04:42:50
 Re: Re: Re: Wire tracers in reply to Wayne, 02-09-2004 21:09:49
Hi Wayne,
One of my worst jobs was on a two story building with 4 refrigeration units on the roof with the walk-in freezers on the first floor. The sparky must had several thousand feet of red wire left over from another job as all the controls for four units were wired with red wire.
The next thing they did was pull L1 & L2 from different breakers for all units. L1 came from breaker A409 while L2 came from breaker A412, etc; Atleast they were in the same subpannel.
Then some "expert" sparky came in and jumped all the safety controls out of two of the units to make them run wide open.
Several days of headaches before I got all the problems back too square one and repaired the faulty units.
They also make a meter that senses current in wires from about a foot away from the wire. I never used one but I thought it would be useful in some circumstances.
The electric utility has a infraed meter for spotting people who are stealing electricity form 1/2 mile away from the source, bypassed meters, etc: I would bet that one costs a pretty shiney penny or two :)
T_Bone
Wayne
02-10-2004 20:29:03
 Re: Re: Re: Re: Wire tracers in reply to T_Bone, 02-10-2004 04:42:50
When I was doing maintenance for Metromont on their concrete plants I had to make up a new control panel for the washout water reclaimation system on one of the older plants. It had been butchered over the years and no longer worked as you can imagine. That along with the fact that I had to consolidate all the controls from 2 different places, one of them 100 yards across the lot at the pond itself, into one place to make it work like they wanted made it a real challenge. I had 14 wires, all the same color going into the main box, which I was eliminating for the new one. When I started tracing them back they all changed colors at least 3 times, and one changed 8 times before I got to the other end. Everytime the conduit went to a junction box, which was just about every direction change, it seemed the wire had been spliced with a new color. That one was reeeeaaaal fun to figure out. To top that we had one 120V circuit that in 2 years I never found where it feed from. You could shut down the main and that would take care of it, but none of the breakers in the panel worked on it, nothing. I stopped in one day about a year after I left and they had some outside contractors working on the baghouses, which is where the circuit went. They wanted the power off of them and had spend all day looking and still hadn't found the source. They asked me about it and all I could do was shake my head and tell them that I always had to work that circuit live. I wish Metromont would have been good enough to poney up the money for a tracer then, but they were just too cheap when it came to tools, and I couldn't afford that much to get one on my own back then.
Wayne
02-08-2004 20:22:19
Hey guys, thanks for the input. Dale, thanks for the straight scoop on the GB unit. I had heard some of the models out there had the problem of the tone bleeding into other wires in a bundle. With it being an inexpensive unit that was one of the main things I asked the other day when I called GB. I was told that under the right conditions it could be a problem, but it wasn't likely. Looks like it is alot more likely than they want you to believe. Like ya'll said you get what you pay for, and it looks like I'm gonna have to spend a little more than I wanted. The main thing though is it isn't worth a dime if it doesn't do what I want or causes more problems than it solves. Thanks again for the advise. Wayne
Rick
02-08-2004 19:16:27
I use a Progressive Electronics toner and inductive tracer for the same type of work. It works good if you have an open circuit. Lowes Lumber has them and I think the two units are a little over $100. Got mine from MCM Electronics.
Dale in I'N'
02-08-2004 06:40:08
If the GB is what I'm thinking it is I bought one from a home supply center to trace telephone wires. It was about 40 bucks. It was a piece of junk. I was running computer / telephone cabling for a friend and it was awful. There were 6 pairs of wires in the cable and just testing the unit it gave me a tone on most of the pairs, not just the wire the tone source was connected to. Go look for a good telephone "Toner". It will cost about 120 - 160 bucks for a good one. It's like the tools you use. Cheap ones = skinned knucles, rounded off bolt heads, etc....
Ol Chief
02-08-2004 17:12:14
 Re: Re: Wire tracers in reply to Dale in I'N', 02-08-2004 06:40:08
The best I have seen is Greenlee. Purchased at Grainger and it was pricey.However it was great. I used it on shipboard where there are hundreds of miles of conductors and never had a problem.Grainger has a variety of these instruments so you might ask them what reports they have gotten from customers.
