Leaking Carb
Frank Tyson
08-20-2000 11:46:34
The carb on my JD "L" from time to time will leak all the gas out through the little hole in the bottom. What causes this and what is the solution? I know that in order to do this the fuel bowl valve is not sealing but replacement will not correct the carburetor problem. It is a regular Marvel Schebler and any suggestions would be appreciated.
Tex Ferguson
08-26-2000 17:22:08
 Re: Leaking Carb in reply to Frank Tyson, 08-20-2000 11:46:34
Hey, Frank, all that expensive gas on the ground could be a fire hazard, too!
Old motorcycle habit is to shut off the tank petcock to stop flow at the source. I installed a NAPA inline fuel filter to protect my MS carb from the rust flakes coming out of the tank. It works great. My problem was rust clogging the jets, and that really slows the engine! Good luck!
Tex
walt
08-20-2000 11:53:52
I have a MS carb also, and it was a float out of adjustment. Have also seen on this board, trash in the gas, that gets under the needle.
