Tool Talk Discussion Forum
Siphon vs Pressurized Home-Built Blast Cabinet?
kwright
02-07-2004 16:10:10
I�m looking for a little guidance/advice regarding SIPHON feed versus PRESSURIZED feed for a sand blast cabinet. Note I currently have one of the small inexpensive siphon units commonly available at TSC and other places, and I�m looking to replace this with something larger.
I�m contemplating building my own cabinet. I understand a pressurized system is superior to a simple siphon system, particularly in terms of compressed air consumption. However, I�m not clear on specifics of the plumbing, that is, how is a pressurized system �plumbed�?
Also, is it practical for one to build their own blast cabinet, using a pressurized system?
Thanks!
Rick
02-08-2004 17:02:35
 Re: Siphon vs Pressurized Home-Built Blast Cabinet in reply to kwright, 02-07-2004 16:10:10
Hi, a guy that I have e-mailed back and forth a few times has a homebuilt sandblast cabinet that is pretty good. The site is www.frugalmachinist.com , look it over. He has some very interesting things he has built. Rick
Frank
02-08-2004 11:24:28
I have a TP Tools Co.blasting cabinet Model 960. I paid around $1000. for it. This cabinet is one of the best tools I have ever invested in. I own & operate Classic & Antique Tractor Repair in Rhode Island and wouldn't ever want to be without it again.
BobCaesar
02-08-2004 08:31:18
First thing is - if there is a pro sandblast shop in your area look into using them. Often they are not as expensive as one might think, AND their equipment is "industrial" compared to what we call blast cabinets for the home/hobby shop.
All the guidance & advice you'll need can be found at TP Tools! They make good sandblast cabinets & sell components for you to make your own. I don't find anything dirty or nasty about using my TP Cabinet! Frankly, I love it!
Their catalog contains a wealth of info on not only their products, but what works & what doesn't. Also their Tec people will gladly answer your questions.
Give them a try;
JDK
02-07-2004 18:21:51
Pressurized cabinet would simply be a box w/window used to conduct blasting ops in with a stand alone pressurized blaster pot/gun.You would periodically have to drain"used" sand from box and return it to pressure pot.While a pressure pot blaster does use a bit less air it is not necessarily a "better" system.I have been using siphon system,siphon cabinet,pressure pot,pot guns for 20+yrs and each has its points.The cabinet in any context simply allows a safer and
cleaner operation and recovery and reuse of media. To use a cabinet for "pressurized" pot blasting,you just bring your pressure gun and line into the cabinet,like you airline normally comes in.I use my foot control airline(for the cabinet siphon)to feed air to the pressure pot inlet,when using the pressure gun.I built my 1st cabinet w/plans book&parts from TiP Sandblasting except that I lined the inside of the plywood box with valley tin as built.That ole cabinet lasted several yrs until I bought a bigger TiP Cabinet and as fart as I know feller that bought it is still prolly cleaning cycle parts in it.
**Just a note here**
I've posted this before as advice---If you are going to spend some cash getting into sandblasting,glassbeading...TAKE THE TIME to find someone who has the system you're thinking of and try it out.Many,many folks out there think"Hmmmm,sandblaster,yeah that'll be the ticket"Sandblasting(hobbyist/home shop level)is a tedious,time consuming,filthy,noisy job.For items that will not fit in a cabinet,you will soon have a regular"beach" of sand in your blasting area unless you lay down tarps etc to recover the sand.
I outdoor blasted an 8N fender a couple yrs back,had almost 5hrs and 500lbs of sand invested.Other fender was derusted(electro)and chemically stripped bare for appx $25.I've heard guys talk about blasting an entire tractor.Most non commercial rigs you should liken this task
to going over that entire tractor at least a couple times with a toothbrush.All I'm tryin to say here is that sandblasting is NOT a magic
wand that causes all the rust and paint to instantly disappear!Before investing the $$$$$ for a GOOD compressor,blasting setup,plumbing,safety equipment etc,BE SURE you want to,and CHECK with commercial blasters for prices on the job.
--OK I'm done now--
kwright
02-08-2004 04:55:57
 Re: Re: Siphon vs Pressurized Home-Built Blast Cab in reply to JDK, 02-07-2004 18:21:51
I appreciate the comments and advice.
One point of clarity: I already do sandblasting... I'm simply considering upgrading my equipment.
I recondition motorcycles as a hobby, so I have a need to clean parts frequently. I also have a local blaster that does large or difficult projects for me. Anything done outside a cabinet is done by my local blaster, also.
Note that I do use a high quality resperator, even when working in the cabinet.
Slowpoke
02-07-2004 22:45:19
And don't forget about the air supplied hood for blasting outside the cabinet.
Benj. J. Joe Browning
02-07-2004 22:19:49
Hello Everyone,
I could not agree more. Especially about it not being a magic wand, but a nasty dirty job. I've found that a combination of aircraft paint remover, wire wheels and sandblasting is the really the best route to go. Joe
