Tool Talk Discussion Forum
husqvarna decompression button
jim ball
02-07-2004 09:37:55
i am thinking about buying a used husqvarna saw.
are there problems with the decompression valve ? why does stihl not use them ?
jeff
02-12-2004 00:12:09
 Re: husqvarna decompression button in reply to jim ball, 02-07-2004 09:37:55
That button makes a WORLD of differance! Be careful if you need to pull back on the valve as some of them DO NOT like to have a twist done to them. Look for little spring clips on the side at the bottom of the assembily. When the saw starts they snap shut, and away you go. I have an older pioneer PM 100 saw that is 100cc, that's 6.1 hp and it has NO button. It is one BULL of a saw, but does it ever cut! As with almost any saw, go to a good saw seller/ service place and check things out.Go to Husky or Sthil web site and look up your local shop by Zip code. Most all of these folks have YEARS more know how than any of us could ever muster! Jeff
Brian in MO
02-08-2004 08:50:14
We use husky cut-off saws they all have them. I don't think the rope would last long without them because you can't hardly get them to turn over without using the comp release.
Timbersavage
02-07-2004 17:47:30
the only problem you may encounter would be that the button could get sticky as a result of carbon build-up throuh non-use,i.e.,, if you decide to push it in and it hasnt been used in awhile. And its no problem to pull it back out manually, just pull with a twisting motion.
good luck, Huskys are awesome saws
HJP
02-07-2004 17:14:16
stihl DOES use them my 046 mag has one !!!
Van in AR
02-08-2004 07:33:32
 Re: Re: husqvarna decompression button in reply to HJP, 02-07-2004 17:14:16
MS 440 has them also. I think they start there and all of the bigger saws have them.
Van
John in MA
02-07-2004 10:11:45
Stihl does use them on their larger saws. Most companies do. Don't sweat it.
Rob
02-09-2004 14:58:56
 Re: Re: husqvarna decompression button in reply to John in MA, 02-07-2004 10:11:45
I think that the decomp valve is standard on Stihl saws starting with the MS360 up to the 088.
