Tool Talk Discussion Forum
Wire Spec
TommyP
02-07-2004 06:32:41
I came across arout 200 ft of # 10 wire. I thought it was aluminum because of its light metalic color, but its heavy like copper. When I cut one of the wires I noticed the inside of the strands were copper. I heard of copper clad aluminum but not aluminum clad copper. Is there such a thing? I'm thinking that maybe the copper has a silver coat to it. How do I know if its a aluminum or siver coat? If it is aluminum or silver can I use it? Thanks
MarkB
02-07-2004 18:19:30
 Re: Wire Spec in reply to TommyP, 02-07-2004 06:32:41
It's tinned wire. This is usually done for corrosion resistance. It's probably fine for most applications, but pay attention to the markings on the wire.
Bob
02-07-2004 09:07:14
Is this insulated wire, and what do you want to do with it? If you intend to use it for code approved electrical work, what is printed or stamped on the insulation is what's important. There will be some designation of what type it is, and also a UL approval listing.
TommyP
02-07-2004 10:01:50
 Re: Re: Wire Spec in reply to Bob, 02-07-2004 09:07:14
There are no markings on either the outside wire or the individual shethed strands. This wire is in good shape although it dates back several decades. There are 4 insulated wires: red, black, white and green and they are inter wound with burlap cords. I'm thinking that the wire was an extension cord as my dad was an ironworker and I have 100's of feet of 2/0 welding wire. I'm guessing this wire probably used for hand tools. Could be industrial. Should I use it to run a circuit to my garage? (house attached) or to the scrap man?
Bob
02-07-2004 11:56:11
 Re: Re: Re: Wire Spec in reply to TommyP, 02-07-2004 10:01:50
If it's in good shape, and older like that, it's probably better made than what's on the market now, and would work great for that purpose.
However, without a voltage rating and other approval information printed on the jacket, you're pretty much using it at your own risk, and I doubt an inpector would approve it's use.
Friendly Fire
02-07-2004 15:12:36
 Re: Re: Re: Re: Wire Spec in reply to Bob, 02-07-2004 11:56:11
Tommy P, I have been a state cert. jym electricain for over 20 years and some of the answers people get when asking electrical questions are downright scarey and could in some cases be deadly. So keep in mind some of the answers are worth what you paid for them. A lot of the guys are trying to be helpful and mean well but some of them just dont know what they are talking about. If you really want to use the wire take it to a electical supply house or ask an electrician and see what you have. There is some old asbestos covered wire still around.
DaveCA
02-07-2004 10:42:31
I would use it for extension cord in open air somewhere I can keep an eye on it. Sounds like SO or SJO. Keep an eye on the insulation for any loss of integrity.
DaveCA
02-07-2004 07:59:13
What markings are on it? Where do ya wanna use it? Power for a structure inhabited by living beings? Within a mile or so of anything flammable? Could be tinned cu or silver plated cu.
