Tool Talk Discussion Forum
Squeeze type bearing greasers
Slowpoke
02-06-2004 11:55:31
Questions, questions, questions!! How do the squeeze type greasers work? Where does the old grease go? Are they better than the cone style that uses a grease gun? It there less mess? I'm trying to decide which to buy.
Thanks
Harrison
02-07-2004 17:15:39
 Re: Squeeze type bearing greasers in reply to Slowpoke, 02-06-2004 11:55:31
You pack two kinds of bearings.The kind that matters and the kind that don't.If it don't matter pack em with a packer any will work.If you are packing bearings that matter to YOU then pack them by hand.Clean and blow dry Without "spinning"and wearing the bearing.Then take the bearing and dip some grease into your palm.Pack until the grease oozzes out the other side all around.Do the rest calculating grease usage and when your done there is no mess.Takes practice to be clean and skilled and quick.Just focus on doing it right and speed will come with practice.
John K
02-07-2004 06:14:02
I use a cone packer with a greese gun. No where did it state to pack the bearing with out cleaning it first. Before I bought the cone packer I thought that it was a wast of money till a friend bought one. I pack mybearing then wipe of any excess greese with my finger and put it in the hub or race as I all put greese there any way. To store the cone Packer, I put it in a plastic funnel that is just a little larger than the packer. On the small end is a plastic plug that is used for plugging hoses, on the big end I use a Basel margerine cover that snaps on. I think that cone packers are the way to go. Have not seen the new squeese one though. DO NOT SPIN THE BEARING WITH COMPRESSED AIR, after a certain speed the centifical force will force the balls or rollers to seze to the inner race. If you have the bearing stuck on a fingure when that happens, kiss it good by. It will litterally tear you fingure off.
John Garner
02-06-2004 19:06:44
Slowpoke --
Back before I bought a bearing packer, I thought the packers were a better way to grease a bearing. Now that I have one (a cone type), I think it a waste of money.
Like Ben, I believe in cleaning old bearings before repacking them; pushing new grease through a used bearing will remove most of the dirty grease, but it doesn't remove all of it. So I still have to clean old bearings.
Then, the packer itself gets greasy when being used. The grease on the packer makes for a gawd-awful dirt-catching mess (even if stored in a plastic bag) if it isn't cleaned, and the dirt and grit and builds up will contaminate bearings. So now I have to clean the packer.
But even a dry packer will collect dust, so it really needs to be cleaned both before and after use.
In the several years since I bought the packer, nobody as ticked me off enough to allow me to give them the packer as a gift, so it just sits in its Zip-Loc bag in the garage.
'Cause I found a better way to pack bearings. Two, actually.
One way is to simply wear a pair of nitrile glove while packing bearings by hand.
The other way is to put the clean bearing in a plastic sandwich bag with a glob of fresh grease then squish the grease into the bearing inside the plastic bag. If you do it this way, you can simply leave the newly packed bearing inside the bag until the moment you install it.
John
Vern-MI
02-07-2004 01:26:00
 Re: Re: Squeeze type bearing greasers in reply to John Garner, 02-06-2004 19:06:44
There is one more way to pack bearings. First clean the bearing of all old grease and contaminates using clean mineral spirits then attach a grease needle to the grease gun and insert the needle into the bearing in and around the ball cage and pump it full of grease. Lay the bearing on a clean sheet of paper on the bench while pumping in the clean grease. This method keeps the hands pretty clean and gets the grease well into the bearing. The grease needles have a zerk on one end and a needle on the other and can be purchased at most auto supply stores and Harbor Freight for about $2 apiece.
Greywolf
02-07-2004 05:18:01
 Re: Re: Re: Squeeze type bearing greasers in reply to Vern-MI, 02-07-2004 01:26:00
Or you can make them yourself for about a buck or less and save the shipping costs.
Take a press in zerk, go to your local vet and get a needle. Press the two together (caution used when handling the needle obviously).
That's all that comprises the ones I've seen anyway.
Ben in KY
02-06-2004 12:26:50
All will be messy. I have used 2 or 3 types. I like the types where you don't use a grease gun so I don't have to keep an extra grease gun with wheel bearing grease in it. Of course if you do a lot of bearings get the grease gun type.
I wash my bearings out with solvent and a soft brush first and air blow them then use the packer to fill them back up. Might not be right, but it has worked well for me.
Slowpoke
02-07-2004 00:23:52
 Re: Re: Squeeze type bearing greasers in reply to Ben in KY, 02-06-2004 12:26:50
I have misplaced my old cone style packer and saw the new kind on Ebay. I figured that the squeezers wouldn't get all the old grease out. I always clean bearings before greasing them and I have one gun with wheel bearing grease in it. I guess I'll get the cone type again if I can't find my old one.
I guess any method will work if the bearing is cleaned first.
