Which AC/DC Welder
Greg Lenz
08-18-2000 22:48:50
Anyone ever use Craftsman Stick welder (Century in reality I think.) They offer a AC/DC stick for a lot less than a Lincoln, Hobart or Miller. I currently use a Lincoln AC 225S but am ready to try a DC.
Very Happy with the Lincoln, but if I can save $100.00 and get good results, I should probably do that. Please let me know what you think. I have never used anything but the Lincoln AC.
Also another question on the DC side. Can I weld very thin metal like 22+/- guage with a DC stick just as I can with a MIG?
Thanks in advance,
Greg
Steve
08-19-2000 20:53:05
 Re: Which AC/DC Welder in reply to Greg Lenz, 08-18-2000 22:48:50
Greg, I was at a sears store and I looked over one of those cheap welders. I did not like the amp control lever on it. It was hard to adjust the amps accuratly. I decided to look around for a lincoln or miller. The hobart is the same as miller. I once had a miller thunder AC/DC. I gave ti to my father-in-law, but I loved the way it welded on DC. And I liked the fact you could get a exact amperage setting. I now have a Lincoln AC welder I bought at a pawn shop for 150 dollars and it works great. Century does make good welders though. I have seen one in harbor freight that is a AC/DC 250 amp 100% duty cycle for 600 dollars. I think these are the same as some of the older Wards welders and I have friends you have those And tell me the have been good welding machines. My opinion is for the money a good miller or lincoln can't be beat. Hope this helps.
Steve U.S. Alloys
08-19-2000 09:53:16
Hi Greg,
With practice, and using the forehand method, you can weld fairly thin sheet metal with a stick welder.
Here's the difference between polarities.
AC= 1/2 the heat in the electrode and 1/2 in the base metal.
DC+= 1/3 heat in the base metal and 2/3 in the electrode.
DC-= 2/3 heat in the base metal and 1/3 in the electrode.
DC+ polarity will enable you to weld AL using a extruded coated electrode.
You may also benefit from polarity changes when welding out of position.
Steve
Scott Green
08-19-2000 18:25:12
 Re: Re: Which AC/DC Welder in reply to Steve U.S. Alloys, 08-19-2000 09:53:16
Steve , very good information you posted here.
Scott Green
08-19-2000 03:29:07
Like I said on the earlyer post , I worked in a boiler factory where most everything is put togather with weld. Many kinds and types , and brand names of welders. Centry is one of the brand names they had. It is also the brand name I was told to stay away from. I have a lincoln AC/DC. With practice , I can weld band iron with it. You can't beat a mig machine for thin stuff. Mine is a stick welder. Very happy with it.
