Tool Talk Discussion Forum
Update: Good price for Lincoln Welder ? New info!
Terry in KY
02-05-2004 06:33:37
I went back and checked on the Lincoln "Tombstone" (which I guess was a bad thing to call it, caused confusion).
The welder is a Lincoln "Idealarc 250" and is marked "AC 30-300 amps", "DC 30-250 amps" on sliding scale. Very, very heavy, has it's own little cart!
I'm not an experienced welder, just done some rough arc welding around the farm, but I like welding and want to (need to) do mroe. Would this be a good unit if it works well? Any way for a novice to test it? He's asking $175, which I think might be a good price based on earlier comments.
Any advise appreciated.
Terry
Fred OH
02-06-2004 08:26:43
 Re: Update: Good price for Lincoln Welder ? New in in reply to Terry in KY, 02-05-2004 06:33:37
Well, you guys are finding out some of my secrets...I bought an Ideal Arc 300/250 new back in the late sixties, terrific welder. Later I decided to buy the TIG attachment for it and I think the TIG attachment cost more than I paid for the welder and I think one of them cost $283...but I don't remember which one. I could over use it with the TIG and smell it getting hot...but that was my fault by not paying close attention to the rating on the welder. Usually welding thick aluminum that dissapated a lot of heat. It wouldn't bother me to have one in the shop again...but I have it's equivalent...an Airco Bumblebee [MA]. It only shows 275 amps on the high AC side...(250 on the DC) but it appears to be heavier built than the Idealarc. One thing about the Idealarc was you could take the handwheel amp adjuster off and mount an attachment from Lincoln that was a gearhead motor that would run the amps up/down from a switch on the stinger...neat for TIG welding...when you're coming up to that edge and need to cut the current down so you won't have that crater at the end. By the way...anyone else running an Airco welder? They weren't as common as Lincoln, Hobart and Miller for the small shops but they're super heavy built. This one has three transformers inside that are welded together with an eye on top to lift it with and I'd say it weighs probably 400 lbs. If I were going to buy the one in question, I'd run some 3/16 rod with it and see how it does after about ten in a row. If it don't smell like windings burning...I'd buy it...take the cover off when I got it to the shop and give it a good cleaning with an air hose. I run mine for over ten years and that was the only maintenance required. Fred OH
John in MA
02-05-2004 15:04:15
Those are great welders. As long as it works and you have the power to run it, it's a good deal.
John K
02-05-2004 13:36:59
I repair welders, I owned an Ideal arc 250 after I seen one that was very well torcher tested. I went into a welding shop to repair a Hobart welder, repaired it but I could smell hot rubber. I traced the smell down to a Ideal arc welder leeds. Some one was welding with 5/32 rod and then lowered the mud skid down on the stinger leed thus shorting it to ground. When I found the leaeds, the rubber dripped off the wire. The welder worked with no problem other than having to come back a week later to tighten up the transformer lamination screws to quiet down the buzzing within. Thhose welders are very robust. You definatly didn't over pay.
Terry in KY
02-05-2004 10:55:35
Sorry guys, but based on the comments I received here (and a little research I did on the net) I went on lunch and paid the guy down payment to hold it until Saturday, when I can go and pick it up.
When I looked at it the other day the owner (older guy) demonstrated it for me -- seemed to work fine.
Thanks!
Terry
TimV
02-05-2004 11:56:59
 Re: Re: Update: Good price for Lincoln Welder ? Ne in reply to Terry in KY, 02-05-2004 10:55:35
Terry: I'm glad you bought it, and I think you will be too. The Idealarc is definitely a better welder than the AC225 "tombstones", and the price you paid is an excellent deal.
KeithF
02-05-2004 09:56:28
If it is the single phase power Idealarc then jump on it fast. I paid $700 for the Tig 300 version and thought I was getting a good deal. They have variable current settings with a fine adjustment. Makes stick welding easy. It also should be adaptable to Tig. Go to lincolnelectric.com and download the manual for it. If it is older than the models shown then they will send one to you free out of their archives. Have fun.
Dale in WV
02-05-2004 09:02:27
Dont listen to those guys. I'm closer in eastern WV than the man from Texas. Just give directions to the fella selling the welder.... :-)
KX
02-05-2004 09:01:08
I would buy it without another thought if it will strike an arc. this thing will outlast you if you take care of it. That is one welder I want but have never found "the right deal" on one. Ones I see on eBay are always too far away.
RobertTX
02-05-2004 08:35:42
I bought a used Idealarc that cost somewhat more than that. I have been very happy with it, they have an excellent reputation. If you decdide not to buy it, I am interested, where are you located?
Dave F.
02-05-2004 07:18:37
Terry, if it will strike an arc & weld in ac & dc in all heat ranges, I would buy it you would probably never have to buy another stick welder again, with the dc. you have a wider use of different rods you can use for various welding jobs, where's this welder located? I may be interested in it if you don't buy it. Dave F.
