Tool Talk Discussion Forum
submerisible pump oil
Dan Z
01-31-2004 21:13:35
I "accidently" opened my submersible pump and found out it was oil-filled. Hmmmmm, what kind of oil do I refill it with and how full should it be? It is a half hp true value pump. Thanks
David - OR
02-01-2004 07:55:39
 Re: submerisible pump oil in reply to Dan Z, 01-31-2004 21:13:35
(The following assumes you are talking about a submersible well pump, and not a sump pump or sewage ejector pump).
Submersible pumps come in two sections. The water end and the motor. The water end should be filled by the well water as the pump operates. There's nothing to refill here.
Most submersible pumps are powered by motors built by Franklin-Electric. (There should be a nameplate on the motor). Franklin's motors are filled with non-toxic antifreeze, not oil. The bearings are designed to be floating and/or water lubricated. The antifreeze has to be non-toxic because it may leak over time and you will end up drinking it. When submerged in the well, well water is allowed to replace any lost antifreeze. (The antifreeze is there so that below-freezing temperatures during initial shipment and storage will not damage the pump. It isn't needed during opeartion).
If you promise not to let the motor freeze, (put the pump assembly back down the well -- don't let it sit in the unheated shop), just fill the motor up with drinkable water.
If you want to replace the antifreeze, it is supposed to be food-grade propylene glycol.
You can read more about it here:
http://www.franklin-electric.com/Manual/AIM_03.htm
jimlll
02-01-2004 12:17:31
 Re: Re: submerisible pump oil in reply to David - OR, 02-01-2004 07:55:39
I have a question on a submersible pump installed on a piece of property that I purchased. What does the "control box" do?
control box
02-01-2004 13:43:13
 Re: Re: Re: submerisible pump oil in reply to jimlll, 02-01-2004 12:17:31
Control box contains the external starting relay and starting capacitor.
Dan Z
02-01-2004 11:03:54
I am sorry, I am referring to a sump pump. I should have made that clear. Thanks.
Bob
02-01-2004 18:08:17
 Re: Re: Re: submerisible pump oil in reply to Dan Z, 02-01-2004 11:03:54
Try emailing:
[email protected]
and ask them for a the name and location of a retailer near you who stocks replacement oil for sump pump motors.
