Tool Talk Discussion Forum
Wood mills
Mark
01-31-2004 16:31:00
Anyone have info on mills. Good or bad brands? I would like to mill up to about 36" trees. I have seen Wood Mizers and they seem like they are made well. Thanks...
Fred P
02-01-2004 18:11:09
 Re: Wood mills in reply to Mark, 01-31-2004 16:31:00
If you are going to be cutting high grade hard wood, get a Wood mizer or one of the other band mills. If you are cutting lumber to build around the farm with. Get a Mobil Dimension and you don�t want to spend all day cutting a few board. They make a little more saw dust. They are quick to sharpen. They cut fast. One person can saw and stack the lumber. One person can run a band mill, but not keep the mill cutting 100% of the time.
thurlow
01-31-2004 17:55:29
Mark; I have found Sawmill and Woodlot Management Magazine to be the best source around; check out their web site..... http://www.sawmillmag.com/
Benj. J. Joe Browning
01-31-2004 17:31:11
Hello Mark, Check out the new Yahoo Forum on Bandsaw mills.
Joe
TimV
01-31-2004 17:03:13
Mark: There's a fair amount of info in the archives on this subject, but I'll add my two cents here. Wood-mizers are indeed well made, and their customer service and product knowledge is second to none, at least in my experience. This is based on 20+ years of owning a Wood-mizer LT-40, and sawing quite a bit of lumber with it. There are other decent band saws out there, and some circular saws as well, but be careful--as with most things, you get what you pay for, and a cheap saw will end up costing you several times more in the long run, in terms of wasted time, maintenance costs, and ruined wood. One other thought--a 36" tree is going to be pretty big for a band saw--most will only handle 30", and many won't go that high, at least not without some fiddling and tweaking.
M.R.
01-31-2004 19:25:45
 Re: Re: Wood mills in reply to TimV, 01-31-2004 17:03:13
Link
