Tool Talk Discussion Forum
piston swapping in chainsaw
Rob
01-29-2004 16:09:56
I am wondering, If one were to find a Jonsereds 670 with a 50mm bore and 34mm stroke, and a cylinder and piston that is made for a different saw with the same bore and stroke, would it be possible to swap the piston only, not the whole cylinder assembly just the piston. Is it possible to do this? My reason for asking is that the stihl 038 piston is a 50 mm bore 34mm stroke dual ring piston and the jonsered 670 piston is also a 50 mm bore and 34mm stroke, but has only one piston ring by design. The design of both pistons is practically identical except for the fact that the stihl piston has 2 rings instead of one.
HJP
02-02-2004 16:52:37
 Re: piston swapping in chainsaw in reply to Rob, 01-29-2004 16:09:56
The ONLY reason I did this was due to the fact I had a $20 parts saw advailable vs. $130 top end.
jokers
01-30-2004 19:20:01
Hi Rob, What exactly are you hoping to accomplish by installing the two ring piston in your 670?
Russ
Rob
01-31-2004 13:33:51
 Re: Re: piston swapping in chainsaw in reply to jokers, 01-30-2004 19:20:01
What I am hoping to accomplish is higher cylinder pressure resulting in more HP and torque. plus with 2 rings instead of 1 I hope to have a longer lasting engine, better fuel economy, better cooling capability and save money by using less gas.
jokers
01-31-2004 22:07:57
 Re: Re: Re: piston swapping in chainsaw in reply to Rob, 01-31-2004 13:33:51
You`re puttin` us on right? In another saw related post you took the position of the expert in giving advice, and then you expect me to take your reply to me at face value as serious? If your re-engineering of the 670 is going to produce all of those wonderful results, don`t you think that Jonsered would have incorporated them from the beginning?
BTW,who ever says "one ring equals farm saw, two equals pro saw" missed the whole picture by a country mile.
Russ
Mike in WI
02-01-2004 10:27:32
 Re: Re: Re: Re: piston swapping in chainsaw in reply to jokers, 01-31-2004 22:07:57
LOL, Jokers - Where do these ideas come from? Pass the info along to DozerDan that it is a waste of time to perform mods on the single ring Dolmars as "a single ring = farm saw".
HJP
01-29-2004 21:05:36
I swapped a johnsered 0920 piston with a 0930 same principle one ring for a two ring, do check the piston height from the wrist pin even a slight height difference changes the compression significatly.
bob
01-29-2004 20:53:29
as long as they are identical size & shape (wrist pin in same position?) you can. Stihl, Husky & others have models with same cylinder but different ring count. 2 ring is pro saw & 1 ring is ranch saw.
rob
01-30-2004 13:19:36
 Re: Re: piston swapping in chainsaw in reply to bob, 01-29-2004 20:53:29
I Think I will look at the piston and try to find out it they are different. Thanks for the help.
