Tool Talk Discussion Forum
chainsaw
Paul
01-29-2004 13:41:08
im having trouble with my chainsaw. it runs for a short time then cut off and i start it and it runs for about 3 seconds and cutt off again. could anybody help me with this i need help asap
thanks!!
treeboy
01-31-2004 07:21:16
 Re: chainsaw in reply to Paul , 01-29-2004 13:41:08
make, model, how old is this saw?????
Unimog
01-30-2004 06:23:10
I had a problem like this and it was the spark
plug. Cheap to replace and an easy fix for my
saw. Try to avoid Champion plug.
Rob
01-29-2004 16:01:06
It sounds to me like you should probaly rebuild the carb on your saw. What make and model do you have? If its a common model I can probably get you pointed in the right direction for parts to rebuild the carb. and while you're replacing things, I would recommend replacing the fuel lines that go to the carb from the tank, they are probably cracking or broken open. But when you replace the fuel lines, DO NOT buy the home improvement brand line as they are a cheap roll of garbage, instead buy the replacement fuel lines and a new filter as well from a servicing dealer. The whole repair job provided you do it yourself, will most likely cost less than $35 USD to do.
