Tool Talk Discussion Forum
WHAT KIND OF WELDER SHOULD I GET?
gLYNN
01-29-2004 12:05:02
I AM A BEGINNING WELDER. I NEED A WELDER TO WELD STEEL TUBING FOR A ROLL CAGE AND I'M NOT SURE WHAT TYPE OF WELDER WOULD WORK THE BEST. ANY SUGGESTIONS WOULD BE EXTREMELY HELPFUL
T_Bone
02-01-2004 03:33:58
 Re: WHAT KIND OF WELDER SHOULD I GET? in reply to gLYNN, 01-29-2004 12:05:02
Hi glynn,
Any of the processes will work well, SMAW (stick),
Mig (GMAW), solid wire with gas shield
FCAW also called innershield or dual shield when a cover gas is used. Hollow Wire with flux on the inside.
Tig (GTAW)
With smaller tube diameters work best with Tig as it's easier to control the arc.
For all around use, hard to beat stick. Do search on this website forum for welding. Alot of good info has been posted.
T_Bone
Nick
01-31-2004 18:09:18
When using a wire welder, you need to take shielding gas into consideration. It will produce higher quality welds than the flux core wire.
rollo
01-31-2004 05:47:50
Don't know what size or type of tubing you are planning to use, but a good Millermatic or Lincoln MIG welder would work better than a stick welder. If the metal is some exotic type, a more specialized welder may be necessary. I'd also rent a friend who knows how to inspect welds if you're building a safety device...which is what a roll cage is.
big john
01-29-2004 13:42:29
just learning to weld and working with roll cage tubing' most being chrome moly. your best bet is a small mig welder, once you get used to it with scrap tube you can weld most metals. good luck
