Tool Talk Discussion Forum
Compressor won't shut / revisited
Buck
01-28-2004 11:56:13
Hi guys, first of all, thank you for all your help and advice with my Ingersoll-Rand compressor. I called the local Ingersoll-Rand repair center today and ordered the new parts, pressure switch, two pop off valves, gauge, and mis. fittings. Grand total $198.00 The sales clerk does not suspect there was any damage in letting the compressor run all night! Thanks again.
old
01-28-2004 12:23:43
 Re: Compressor won't shut / revisited in reply to Buck, 01-28-2004 11:56:13
Glad to here you have parts comeing but ouch they is high for that one
Rusty Jones
01-30-2004 08:09:58
 Re: Re: Compressor won't shut / revisited in reply to old, 01-28-2004 12:23:43
My Emglo compressor wouldn't "unload" and shut off normally, it would stall the motor! After much fussing with it, i finally took the cover off the pressure switch, and sprayed contact cleaner in there! I let it soak for a day, and now it seems to be operating o.k. Although i don't use it much in winter, it shuts off like it should, when i do turn it on! I found, when it was messing up, if i shone a heat lamp on it, it would shut off! I guess after 20 years, it needed a rest! Rusty Jones
Rusty Jones
01-30-2004 08:07:43
