Stuck Valve
David B
08-14-2000 20:47:25
Got a question. What is the best way to free up a valve. I have a cub cadet 127 that has the check valves (tow valves, release valves or whatever you want to call them) stuck in the tow mode. Guys on the garden tractor board suggest PB Blaster penetrating oil along with the usual tap to start vibration. The valves are out of the hydro unit now and are soaking pin down in PB now. Just thought I�d ask. Saw the water and molasses trick to remove rust and thought maybe someone had a secret out there. David
Dean
08-15-2000 03:56:54
 Re: Stuck Valve in reply to David B, 08-14-2000 20:47:25
David, you're doing exactly what I would do!
