Tool Talk Discussion Forum
Cat III hitch for various makes....
IHC Red
01-27-2004 22:27:39
A local farm store has a hitch kit which can be adapted to fit a full-size Chevy, Ford, or Dodge. The cross tube telescopes on each side for different frame widths.
Are there any dark secrets I should know before I buy one of these kits ?
Butch
01-29-2004 07:01:01
 Re: Cat III hitch for various makes.... in reply to IHC Red, 01-27-2004 22:27:39
I went through this myself and it was suggested (here I think) that I go to a reputable welding shop and price a hitch. To my supprize they quoted a very nice welded hitch that is at least twice as heavy as any factory job for 2/3 as much money. I am very glad I went that route. When talking class 3 loads and stresses you should be concerned more about the quality of the hitch than how easy it can be moved of installed IMO.
Dale in I'N'
01-28-2004 17:56:53
I got one of the hitch kits that you described for my 3/4 ton Dodge. Thought when it got it I was savin money. It also has adjustable back so you can riase or lower the ball depending on what you were pullin. I've moved it to my 97 1/2 ton Dodge. The bad side is the square tubes used to make it adjusable to the chassis has play. It clanks and pulling loads heavy and sometimes light the play and clank in the square tubes really make my eyebrows rise. I wish I would have had the $ to get one made for the truck I was using. Even though I just got done plullin a trailer for three days haulin around garden tractor /w blade and snow blower.
Van in AR
01-31-2004 04:44:24
 Re: Re: Cat III hitch for various makes.... in reply to Dale in I'N', 01-28-2004 17:56:53
Those adjustable hitchs are junk. If you have one and the load is not too great you can weld it up after it is bolted up and get rid of that "is it loose" worry.
Van
IHC Red
01-28-2004 22:17:07
Sounds like a bad deal. I was hoping to reuse it on a different truck. I'm rethinking my options now. I think I get get the solid unit for $10-$30 more.
Thanks for the reply.
Keith--OR
01-28-2004 22:29:13
 Re: Re: Re: Cat III hitch for various makes.... in reply to IHC Red, 01-28-2004 22:17:07
Get an EASY LIFT and you won't be sorry
my .02
T_Bone
01-28-2004 13:29:49
Hi IHC Red,
I personally think most newer receivers are underdesigned for the weight class rating they have. I sure wouldn't abuse them beyond there rating and I would look at the class V, 2-1/2" square before buying the lighter class III.
T_Bone
IHC Red
01-28-2004 17:22:52
 Re: Re: Cat III hitch for various makes.... in reply to T_Bone, 01-28-2004 13:29:49
Thanks T-Bone...
It's for a half-ton Ford, and I think my max tow would be about 5000 lbs... easy pulling on highways. I have to rent a trailer and tranplant my 1949 Farmall C about 120 miles.
Troy
01-28-2004 21:14:17
 Re: Re: Re: Cat III hitch for various makes.... in reply to IHC Red, 01-28-2004 17:22:52
stay away from the adjustable hitches I have seen them brake for what you want go for an ez-lift or reese made for your truck
IHC Red
01-28-2004 22:13:40
 Re: Re: Re: Re: Cat III hitch for various makes... in reply to Troy, 01-28-2004 21:14:17
Thanks. I was hoping to reuse it on a different truck someday, but I better not.
RWK in WI
01-29-2004 06:27:47
 Re: Re: Re: Re: Re: Cat III hitch for various make in reply to IHC Red, 01-28-2004 22:13:40
After a couple of months in the wet and maybe salt it will be so rusted you can't readjust for a different truck anyway.
