Tool Talk Discussion Forum
Spark plug seat tool
Tom
01-27-2004 20:02:17
The problem: The seat that the spark plug sealing washer sits against in the head of a Farmall tractor has been corroded to the point that it no longer seals when the tractor is running.
Does anybody make a tool to mill the spark plug seat without having to remove the head and take it to a machine shop?
Bob Whitmoyer
01-28-2004 13:58:30
 Re: Spark plug seat tool in reply to Tom, 01-27-2004 20:02:17
Hi Tom
Here's a poor man's remedy.. 1. Take a old spark plug that fits the tractor
and grind the threads off carfully but completely. Remove the washer
2. Wrap the porcelin with a couple good turns of duck tape.
3. Gather some of the clean grinding dust from
your grinder, mix with a little light oil to
make a paste
4. coat the spark plug area that meets the corroded part of the head and the head area.
Chuck up the plug in your drill (reversable)
insert in hole (little greese on the stub (thread
area) spin fwd for a second or two, reverse a second or two. Add grit and repeat - patience
is golden
Note- good plan to bring that piston to TDC before the procedure and afterwards fill with kerosean and spin the motor X 2-3 to clean any grit and stuff
out before runing the motor
kind of plan B - Bob
Slowpoke
01-29-2004 01:30:10
 Re: Re: Spark plug seat tool in reply to Bob Whitmoyer, 01-28-2004 13:58:30
I would rather try a little fine valve grinding compound with your method, but still would be worried about it getting in the cylinder. Maybe removing the head first would be best.
Scott
01-28-2004 09:05:21
Tom
Check with your local machine shop and see if they have a tool and if they can come to the tractor and make the repairs. My local machine shop makes house calls, it just depends on how busy they are.
