Tool Talk Discussion Forum
Welder to build a trailer
Scott
01-27-2004 13:49:47
I've got a 110v Hobart wire welder on stargon gas. I've been looking for a project to tackle, and what I've been wanting for the past two years is an 18' beaver tail trailer for hauling my tractor on.
Is my welder big enough to handle such a task? I realize it'll be a lot more work if it is, but my only other option right now is a 220v stick welder, and I'm not too good at verticle welds with it.
So, what do you think? Buy one, or build one?
333
02-04-2004 15:00:47
 Re: Welder to build a trailer in reply to Scott, 01-27-2004 13:49:47
a 110 is not big enough, I built one with a miller 250 and it worked good, we did use my forney stick welder some of the time, If you can find some used axles and another trailer to copy, you will do ok You can buy some new steel at wholsale at some salvage yards, I saved money, but did not count my labor or my friends labor, who happened to be a certified welder, out of work, pay attention to which way the welds go , this can weaken some parts, still have the trailer, almost 20 years later, hasn't fallen apart yet
mike
01-28-2004 20:46:29
buy it
KX
01-28-2004 13:26:30
Unless you have the steel already, you will spend more building one than you could buy a manufactured trailer. remember these guys are tooled up to do quality and proven design work and they can do it in 1/20th the time it will take you. Time is money too.
You said heavy trailer right? Like to haul a tractor...I don't think you are gona be able to permanently bond iron with that small welder. You don't want to half a__ something that will get you killed or kill someone else on the highway the first tim you throw a good load on it.
Just my opinion but I would start with a much smaller project and move up, then after you feel confident and still want to build a trailer and have the time and resources, by all means noone should discourage that. I think every one with an opinion here is just trying to help you from learning the hard way like they did in one form or another....me included.
UpDate Weld Testing. T_Bo
01-28-2004 13:21:43
Hi Scott,
I agree with the others as your not ready to tackle such a large important project at this time. I personally think you could put your effort into learning more about welding before taking on this project. Once you up your welding skills to an acceptable level then take a look at your trailer project.
How to accomplish improving your welding skills is to practice on test plates then test those weldments. Easy to do and just requires your time. By using the below test method you will soon learn your 115v machine doesn't have the capiblitys to make the welds required on your trailer project.
The key to being self taught is not to "cheat" while testing the weldments, anotherwords don't say, ahh thats close enough. If the welds will not pass the tests then you need to practice more then retest your results.
Weldment testing: UpDated: 01/28/04
To run a simple plate weld break test, take a 1/4", 3/8" or 1/2" plate, with a root opening 1/2 times your electrode diameter to a maximum root opening of 1/8". Tack weld both ends. Then make make a weld pass in the position desired but not less than one test plate in the flat, verticle, horizontial and overhead positions.
After the weldment has air cooled, place the test piece into a vise with the weld being horzontial with the vise jaws and with the weld bead located well above the top of the vise jaws, then apply pressure towards the weld bead face with a pipe wrench with a cheater pipe.
This will cause the weldment to break into. Now compare both haves of the weld test piece. The weld should idealy break down the center with a equal amount of weld on both pieces with a equal amount of penetration. If not practice until it does or close too it.
Another simple test is a T test. Take two pieces of flatbar and place one flatbar on the other in a T shape, then tack weld either end, then weld a one side fillet weld, then let air cool then break with the weld with a BFH. Compare the weldzone as described above.
The above is a good skills test. Once your test pieces are breaking clean on both sides and with equal penetration, then move on to the advanced plate weld testing.
Advanced weldment testing:
Once again prepare 6" long x 3" wide test plates by beveling each piece 22.5* with leaving a 1/16" to 3/32" land with a root opening 1/2 times your electrode diameter to a maximum root opening of 1/8". Tack weld both ends. Then make make a weld pass(s) in the position desired but not less than one test plate in the verticle, horizontial and overhead positions.
After the weldment has air cooled, mark 1" in from either end then mark a strip 1-1/2" wide along the width of weldzone anywhere on the unmarked area then cut out the 1-1/2" wide cupon with a torch, then grind the weld face flush with the base metal, then grind smooth all edges of the cupon leaving no scale on either surface. It's impotant to make the cupon as smooth as possible so it will slide thru the bend test dies easy.
Now place the test cupon on radius dies having a diameter of 8 times the cupon thickness, for a 1/4" thick cupon thats a 2" radius bottom die with a 1-1/4" radius top die, then center the weldzone with-in the top die, then apply pressure with a hydrulic bottle jack to the top die until the test cupon bends into a U shape.
Now observe the weldment area both on the face and the root as well as both edges. The weld area will be very easy to reconize as there will be good visual detail of the molten puddle "V" as it bonds to the base metal with the base metal being lite in color and the weld being a slightly darker color.
If the test cupon was bent U-shaped without breaking into with no discontinuties, or any slag intrapment with-in the weldment is less than 1/8" total area or any crack with-in 1/16" of the weldment edges, has passed the basic plate test for certified weldors.
T_Bone
VaTom
01-28-2004 14:37:30
 Re: Re: Welder to build a trailer in reply to UpDate Weld Testing. T_Bo, 01-28-2004 13:21:43
T_Bone,
Fantastic. It's great to get a welding class here. I'm sure I'm not the only one to print out your lectures. This goes with the one on vertical welding. Thought I was making "gorilla welds", strong and ugly. Now I'll have to see if they're only chimpanzee (still ugly, but not so strong). If it ever warms up enough to weld with the shop door open again....
Thank you.
T_Bone
01-28-2004 22:30:07
 Re: Re: Re: Welder to build a trailer in reply to VaTom, 01-28-2004 14:37:30
Hi Tom,
Haven't heard from you in awhile. You keeping warm over there?
Glad I could help. Ya them simple tests tell it all.
One thing no one ever comments on, is the info easy to follow or confusing?
T_Bone
VaTom
01-29-2004 04:51:48
 Re: Re: Re: Re: Welder to build a trailer in reply to T_Bone, 01-28-2004 22:30:07
Hi T_Bone,
I have no trouble following what you wrote. Not sure my old grammar teacher would approve of it all, but she's been retired for quite a few years now, so she probably won't come knocking at your door. If she does, watch out for that ruler and a sharp tongue. Little chance of her approving your use of "BFH".
It's winter here and we've already had our normal snowfall of 18�". Yesterday was sunny so we didn't bother with heat last night. House is 66� this morning without help, ice covering everything outside. I don't like to weld without the shop door open so that'll wait a little. We like four seasons.
Have you had a frost?
T_Bone
01-29-2004 22:43:51
 Re: Re: Re: Re: Re: Welder to build a trailer in reply to VaTom, 01-29-2004 04:51:48
Hi Tom,
Ya, the past couple weeks I seen ice on the windshield. So weird to see ice here in the desert.
T_Bone
Mark
01-28-2004 07:53:22
Boy,
Some of these guys were negative on trailer building. I don't think that is an adequate welder to do the job. I have the 230v Hobart and its great. I think you need to go to 230v if you are going to build a safe project. Nonw on the other hand I just bought a used Zieman 12', dual axel, with surge brakes for $400.00. It's a 10,500 lb capacity trailer. I'm about $100.00 into for minor repairs. Now for a little more than $500.00 I've got a $3000.00 trailer. Check the used ones first.
Bob
01-27-2004 16:40:01
Scott, I don't want to seem like a downer but if you don't know anymore about welding than the questions your asking indicate I would strongly suggest that you start with something else and work your way up to the trailer regardless of the welding equipment you have. For your own safety as well as others on the road I suggest that you take a short course in welding before tackling a job of this magnitude. Welding is a wonderful thing to know and you well never regret learning. Good luck..... ..... ..... .
BillWV
01-27-2004 16:34:28
You could buy a bigger welder and then build a trailer.
I built a 16' dual axle trailer with a 110v, 100 amp stick welder. It took a lot of time, because of the 20% (or less) duty cycle.
The problem with the wire feed welders is the weld will look ok, but doesn't have adequate penetration.
Good luck,
Bill
John R
01-27-2004 15:23:50
Go to www.kaufmantrailers.com They make a real good trailer for the money. I have two of their trailers and like them both. When you talk to them tell them that you want it DOT rated and inspected. They will deliver to you a trailer that is ready to go and will pass all inspections. I couldn't build for the price they quoted me. Have not had any problems and am very happy with their trailers.
old
01-27-2004 15:20:41
That 110 welder doesn't have the guts to weld up some thing like what you want, as far as buying one in my area you can find them from around $200 needing some work/lumber up to around $600-1000 new. You can't buy the steel and axles for much less. I built one but I had all the steel and axles just rusting away on the farm any how
rustyfarmall
01-27-2004 14:18:00
You need to check on the price of all of the steel, axles, wheels, tires, etc., and then go out and price brand new trailers that are ready to go, I think you will find that you can't afford to build your own trailer.
Mac
01-27-2004 15:07:19
 Re: Re: Welder to build a trailer in reply to rustyfarmall, 01-27-2004 14:18:00
I think I would also research the buy or build.
Buck
01-27-2004 14:05:57
Hi Scott, careful!. My X neighbor had one of thoses Hobart Handler. I think! He was making some brackets out of 14 GA (.0747) he could not get the machine turned up enough to do the job. He came and got me to help. The only way I could even attempt to get it to run hot enough was to long arc it. This gives you more voltage to a point then it drops off. Not recommended to do this, for a number of reasons. I would want a machine that could run in the 250 amp range with at least .045" wire for a task like you want to do.
