Tool Talk Discussion Forum
Checking preheat temperature
BillWV
01-27-2004 06:15:56
YTers,
Is there any way to check preheat temp for welding other than the Tempil Stiks? For hobby use, expensive equipment is out of the question. Interested for aluminum preheat (250d F) and cast iron (400-600d F).
Thanks,
Bill
Peter (NY) Again
01-27-2004 07:25:17
 Re: Checking preheat temperature in reply to BillWV, 01-27-2004 06:15:56
Heres one for $89.00 that goes to 600df.
Peter (NY)
01-27-2004 07:20:30
I think you could use an Extech hi-temp infared thermometer. Model 42540 goes from -58 to 1400 df. Specialized Products sells it for $149.
T_Bone
01-27-2004 07:50:49
 Re: Re: Checking preheat temperature in reply to Peter (NY), 01-27-2004 07:20:30
Hi Bill,
Like Peter suggested there's infered for about $60 to $80, or a oven thermometer for $10 or lead (wheel weights) starts to melt at 400�, liquid at 500� and parrifin/bees wax at 220�.
If you have DVOM with a type K connector you can also get a type K thermocouple that can read from -40 to 1500� depending on the probe spec's
T_Bone
T_Bone
01-27-2004 07:58:43
 Re: Re: Re: Checking preheat temperature in reply to T_Bone, 01-27-2004 07:50:49
Hi Bill,
One other comment on the bees wax as it can also be used as a flux for many different metals. When I pour bullets if works great for a lead flux.
PArrifin wax leaves behind a residue on most metals but does work on lead. Depending on what welding process your using, I don't think it would be a problem other than with Tig.
T_Bone
