Tool Talk Discussion Forum
Incandescent Bulb Reflector Source?
kwright
01-26-2004 16:53:20
Anyone happen to know of a source for an 8 inch (or so) reflector that can be used with incandescent bulbs? This is the same type of reflector that's commonly found on clamp-on shop lights. I need about six of them.
I can buy the clamp-on units and simply remove the reflectors, but this is a waste as I don't need the cord or socket from these lights, just the reflectors. Besides, in my area, an 8 inch clamp-on goes for about $6.00, so I'd end up spending $36.00 when I only need what's probably the least expensive part of the light.
Thanks...
Rauville
01-27-2004 04:33:23
 Re: Incandescent Bulb Reflector Source? in reply to kwright, 01-26-2004 16:53:20
Our local farm / home supply store always carries them in the "Poultry Equipment Dept." The price is around 2.00 for the aluminum reflector with bulb guard.
Otherwise, Richard has the best low-cost idea with the pie tins. We use big flower pot saucers with cheap aluminum pizza pan liners for our barn lights with fluorescent bulbs. Works great!
Richard
01-26-2004 18:17:28
For years I've used aluminum pie plates with a hole in the middle for the bulb to go thru & screw it in the socket. You won't find a better reflector or cheaper. You used to be able to buy them already made up. They were used in big brooder sheds.
old
01-26-2004 17:12:17
A good elelitric suppy place should have them or be able to get them for you
