Tool Talk Discussion Forum
welder will not idel up when welding
tony
01-26-2004 12:42:02
my lincoln sa200 will not idel up when i am welding. the exciter is not moving the throttle.
ftmerle
01-26-2004 17:04:53
 Re: welder will not idel up when welding in reply to tony, 01-26-2004 12:42:02
I had the same problem. The solenoid was binding. I used wd-40 but I think a dry lube would be better on the solenoid. Teflon based lubricant would be my choice. Good luck!
Mguy
01-26-2004 13:36:25
Tony, I've never seen one of those solenoids go bad , but many times I've had to put the sta-kon back on the terminal to get it to work . Good luck. Mguy.
