Tool Talk Discussion Forum
Vertical welding
Shane
01-24-2004 13:59:27
I am gonna be welding up a frame for a trailer deck and will have to weld vertically in a few places. Haven't had much luck welding vertically before and was wondering what the trick is. What rod is a good one, what angle is the rod held, and do you use more, less, or the same heat as a similar flat weld. The problem I have is there are big balls of slag building up and getting in the way of the weld, thinking maybe it is the wrong rod, currently using 6018. Thanks for any help, Shane
Gene Davis (GA.)
01-25-2004 19:04:14
 Re: Vertical welding in reply to Shane, 01-24-2004 13:59:27
Won't offer any advice on how to overhead/vertical weld too much good advice on here for that. Will tell you how not to do it. I came to work one Monday after a FUN week end, and climbed up the 30' of ladder to resume overhead welding with the 7016 rods and got ready and noted I had left my gloves on the ground and still had on my wedding ring,. OH WELL-- that stuff is for sissies I thought! Wrong! About 5 minutes later when I felt and smelled the hide burning where the 7016 flux had hit on the ring and stuck to it as it rolled down and there was not much to do but smell it and make my way back down the ladder with a badly burned hand! Moral of the story is--- gloves are for your own safety and protection!! So remember to use them. I Know!
Davis In SC
01-25-2004 19:19:21
 Re: Re: Vertical welding in reply to Gene Davis (GA.), 01-25-2004 19:04:14
Gene, that story makes me glad I am single..... ... Regards Davis In SC
Ben in KY
01-25-2004 21:36:25
 Re: Re: Re: Vertical welding in reply to Davis In SC, 01-25-2004 19:19:21
Married, but wear no ring. Have a friend that lost a finger because of a wedding ring. Shorted out a battery cable to ground with his ring and burned his finger mostly off, the DR. finished the job for him.
Had my wedding ring mashed down bad on my finger once, wound up cutting it off with a pair of cutters ( lost a bit of blood in the process) before my finger turned fully black. The wife got the ring fixed, haven't worn it since.
T_Bone***UpDate File
01-24-2004 20:24:46
Hi Shane,
Below is a reprint from my previous thoughts.
For the ones that are keeping there own copy, I updated this content.
(Edited for content 01/24/04) Please update your files.
Vertical up welding is fairly easy to do once you get the hang of it. Electrode angle pays a very important roll, about 5* to 10* down from horizontal, 0* works best sometimes, and you need your head below the rod to see the weld puddle with a close arc length and a slightly faster travel speed.
Vertical down welds are allowed by AWS code and are limited to 2" in length on fillet welds but most welds fail when ran verticle down as it's very easy to trap slag with in the molten puddle. I only recomend very experienced welders use vertical down. Learn verticle up first!
Now most welders watch the "slag" in the molten puddle and not the molten puddle it's self and that causes the molten puddle to fall or the weld puddle will slump before the welder moves the rod upward. Thats why we teach you to weld flat first so you can reconize the weld puddle from the slag. If you can see the difference in the weld puddle and the slag, then do not let the slag take your attenion away from the motlen puddle in the vertical position like it does to most weldors.
A vertical weave bead is made by starting a weld puddle then moving horzontial, 8 rod diameters max, then pause slightly to deposit more weld, move up 1/2 rod diameter, then back to the starting point. The horizontal move should be fairly fast so if the weld slumps in the center then your moving too slow. If the ends are under cut then your not pausing long enough at the corners. Take a stratch awl making two vertical lines will help you keep the weld straight and uniform width.
The 8 times the rod diameter maximum is so the slag does not cool before you return to deposit more metal thus intraping slag with-in the molten puddle.
Use your arc length and travel speed to adjust for different welding positions. There no need to adjust amps from flat welding to overhead welding to verticle welding. This is very important too learn for when welding in a 6G position. A 6G position is a pipe fixed at 45*.
Which has a colder heat displaced content; 1) a long arc length, 2) a short arc length ?
A long arc length as the heat is spread over a wider area. This is why a short arc length is much easier to control the molten puddle.
My method of teaching is to have the welder try to move too fast, too slow, long arc length, short arc length, rod angle at 45*, at 5*, too many amps, too low of amps, etc: and pay close attention to the changes each makes in the weld. I reverse teach, "what makes a bad weld". If you know what causes a bad weld then you will know how to correct it when you make that mistake.
This is also where your plastic welding lens will fail you the most. You now have two weld puddles due to the distortion of the plastic lens. Which one is the true weld puddle?
Use only a all glass lens.
T_Bone
T_Bone***Corection
01-25-2004 03:28:13
 Re: Re: Vertical welding in reply to T_Bone***UpDate File, 01-24-2004 20:24:46
Well I caught one major mistake on the previous post dated, 01/24/04.
This is the corrected file below:
(Edited for content 01/25/04) Please update your file.
Use your arc length and travel speed to adjust for different welding positions. There is no need to adjust amps from flat welding to overhead welding to verticle welding. This is very important too learn for when welding in a 6G position. A 6G position is a pipe fixed at 45*.
Which has more heat displaced content; 1) a long arc length, 2) a short arc length ?
T_Bone
Robert
01-25-2004 03:44:07
 Re: Re: Re: Vertical welding in reply to T_Bone***Corection, 01-25-2004 03:28:13
Very good information.
You can make a degree symbol � by using Alt+0186.
22�
varmint
01-25-2004 12:02:40
 Re: Re: Re: Re: Vertical welding in reply to Robert, 01-25-2004 03:44:07
OR 'option + 0' on a Mac ----- 180�
T_Bone
01-26-2004 04:19:34
 Re: Re: Re: Re: Re: Vertical welding in reply to varmint, 01-25-2004 12:02:40
Hi Robert,
Well I tried that and it don't do a thing in XP Home. Did they not include a character map like Win98?
Suggestions?
T_Bone
RusselAZ
01-24-2004 19:58:11
Which pass? Or maybe I should ask how many passes are you going to be making? Each pass is done differently. If your slag is getting in the way you are welding to cold. 6018 should work but I would use either 6013 or 7018. 7018 if you have a DC welder. 7018 doesn't like to work with an AC welder as it is really hard to make a good arc with it. The heat you use will depend on how heavy the material is but 130 to 150 amps with 1/8 rod should work well. Forget trying to do a vertical down and then saying you have welded anything. It's almost a worthless weld though it will stick together. So will gum.
Depending on how well the joint has been prepared will dictate the rod used for the first pass. If it is rough or has a gap or is close and gapped (as it often the way after a torch cut) use a 6011 rod for the root weld. It will freeze fast with little slag. Makes it easy to fill the gap if need be. Second pass use a rod that is strong and will look nice. The slag on the second pass will look like a whole bunch of scrotums on top of each other, (sorry, but it does) if it is done right. On the first pass the slag will look like candle wax does when it runs down the side, making little teardrop shaped balls one on top of another.
As to the rod path, On the first pass it is just a vertical wave with a twist. Sure is hard to try to tell how it's done. Let's see. its a up and out(making a longer arc on cold metal then back in and down, shorting the arc into the metal then pulling back just a bit away from the pool then back into the pool and up and pull back a bit. You are using the longer arc at the top of the weld to preheat the material and to gain molten metal to pull back down and deposit in the bead. And the up and out gives the pool time to just cool a bit so it won't blow out with the next weave. Don't try to hurry it, if you are to cold, the rod will stick when you poke it into the pool puddle before you do the up and out move. If you are to hot it will blow thru. What make the vertical and overhead hard is you have to control the molten metal to freeze where you want the weld to be.
On the second pass you weave side to side, how wide is dependant on the number of passes but assuming you will not need more that 2 passes it is a pretty short weave and done in a very flat figure 8. You use the arc close to the side of the first pass till you get a nice little puddle then you move across the previous bead and hold the arc close to the other side till it makes a molten puddle then you come back across. If you have the right temp the slag will go to the center of the weld and makes those little teardrop shaped two things close together.
I'm sure I have confused you. Sure wish I was there to guide your hand till you get it. Remember, watch the molten pool. What it is doing is all you need to know. It's not easy to do a vertical or overhead unless you have done a lot of them but, when you finally do it right it isn't hard.
kyhayman
01-24-2004 19:44:37
I use a 6011 set the same as I do for downhand or 1 'click' lower amps (Lincoln 225 AC). Short arc, handle down, rod tip up going down with a tight slow whip arc length about 1/3 shorter than downhand (down hand I use a 1/8" arc with a 1/8 rod). Oh, an dLOTS of practice, welded for years before I ever trusted my verticle welds on a load like a trailer.
Randy
01-24-2004 17:55:24
It's been a while since I stick welded. We use wire and heli-arc for everything but, if I remember right we reversed the leads when stick welding vertical (reverse polarity). The positive would then pull the puddle into the weld instead of falling out. Like I said it's been awhile.
Buck
01-24-2004 15:24:09
Hi Shane, I don't totally agree with Alvin, I do agree you will be better off with 7018. I run my overhead just a little colder that I do with flat. Now vertical I run a lot colder. I always whip any rod no matter what! This forces the slag to trail the puddle. When running vertical have the rod pointed upwards slightly, and move side to side in a very small U motion, if you get into trouble or the machine is to hot switch to a J motion and run out of the puddle then back into it. This also works when one plate is thicker than the other, keep the long side of the J on the thicker plate. Keep the rod jammed in real close. Now some wire feed wires, like intershied you point the gun down slightly only after building a shelf. It's really not that hard.
Alvin n Ms.
01-24-2004 14:43:14
Shane, I nearly always use 7018, rods, even though 6011s are recomended. The 7018 welds are very strong, and the welding supply people say they are stronger than the mild steel metal. If you will just type T Bone in the search block at the top of the page, and click on GO you will find several pages, and many post about welding. alvinnms
Alvin n Ms.
01-24-2004 14:24:52
Joe Posted 11-19-2003 at 15:41:45 [Reply] [Send Email] 67.27.3.126-122748 ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- --
Have tried to respond to the messages on welding but somehow it never was posted. The talk just brought back memories of learning to weld overhead and vertical. I learned in Ms. in the early 70's welding trusses. Setting on a 5 gallon bucket welding vertical, closing a 1 1/2 v-groove. The stringer would get so hot we would drop them into a bucket of water to cool them down so we could hold them. A cajon from south Louisiana showed me the art of welding and later I certified through the Pitt Lab test never forgetting the lessons learned,#1 know how to set your welder, 2 wear protective clothing esp. on overhead, 3 don't let the stuff falling out of the weld scare you just maintain a short arc and control the molten pool. Never whip a 7018 rod in any circumstance. Mild steel rods ok. If your machine amperage is correct you should't need to whip that electrode much at all. Always weld uphill with that lo-hi rod and you won't have a lot of porosity in the weld. Understand that if you weld downhill with lo-hi the penetration will be minimal. Let the magnetic force work for you, don't be afraid of the heat or the slag falling out of the weld, keep that arc tight and remember that all rods are for specific welding and are only as good as the person holding the stinger. Oh and by the way the best welders are women, they are more steady.
Mel in Iowa
01-27-2004 07:05:23
 Re: Re: Vertical welding in reply to Alvin n Ms., 01-24-2004 14:24:52
Lots of excellent information here. The only point that I can see concerning vertical and overhead welding that is not completely covered is almost covered by alvin when he says not to let the slag bother you. I have told many novices that if you are going to weld overhead or vertical, you will have to tolerate small burns. The only thing you can do is minimize them. Mel
